Question about Asrock P4V88 (P4V88 RAID) Motherboard
I have an asrock p4v88 mb with 2gb mem and am trying to install seagate baracuda 1 tb hd bios says drive not detected any answers vern
  • Asrock Master
  • 3,606 Answers
Try to upgrade your drivers for the mainboard
from here:
http://www.asrock.com/mb/download.asp?Model=P4V88
Remember to select the windows you are running.
Upgrade the 4 in 1 driver first, and the SATA RAID Driver.
Hope this solves your problem.
Posted on Mar 21, 2011
Boot usb P4V88
Hello download the manual here:
http://www.asrock.com/mb/VIA/P4V88/?cat=Download
http://www.asrock.com/mb/VIA/P4V88/?cat=Manual
You have to enter the bios boot settings, and select to boot from the usb drive, as first boot device .
The file on the usb, must be a iso file so the pc can boot from it.
When you have installed your operating system, you can change the selection again (harddrive as first boot device) to prevent damage to the new install.
The iso file on the drive, can also be burned to a disk.
Here is a great program for the job:
http://cdburnerxp.se/en/download
Its free.
But do select the lowest possible burn settings to prevent damage to the operating system.
Best of luck
If you do this you have to select the cd/dvd drive as first boot device, in the bios settings.
May 08, 2013 | Asrock P4V88 (P4V88 RAID) Motherboard
Does asrock p4v88 motherboard support low and high density?
Hi, you can download a user manual here:
http://www.asrock.com/mb/manual.asp?Model=P4V88
Here you also find drivers.
And remember to select your operating system.
Please unzip the file before installation.
Aug 29, 2011 | Asrock P4V88 (P4V88 RAID) Motherboard
Asrock P4V88 SATA RAID 1.5 Windows 7
No drivers for windows 7, here at the homepage:
But try the VIA drivers from here:
http://www.viaarena.com/drivers.aspx
This mainboard will probably only only run the 32 bit system.
Good luck
Feb 12, 2011 | Asrock P4V88 (P4V88 RAID) Motherboard
Drivers for windows 7
Hello try the via homepage here:
The mainboards homepage, only supports windows xp:
Best of luck
Oct 11, 2010 | Asrock P4V88 (P4V88 RAID) Motherboard
Dual channel Mode willnot work over 2 gb's of
Hi, please read page 12, section 2.3 in your manual. Dual channel memory must be connected per manual specs.
(Correct colored DIMM slots)
Link to Asrock manual; ftp://174.142.97.10/manual/P4V88.pdf
Main web site provided by Asrock; http://www.asrock.com/mb/overview.asp?Model=p4v88
Once the memory is installed into the correct colored DIMM slots your system should see up to just under 4GB if 4GB is installed while using windows XP. (Refer to Asrock's web site).
Hope you find this helpful and working.
Mike
Aug 01, 2010 | Asrock P4V88 (P4V88 RAID) Motherboard
How to use sata raid
Open the links provided below to help setup an array; http://www.pcstats.com/articleview.cfm?articleID=830
And; http://www.pctechguide.com/tutorials/RAID.htm
Motherboards that support RAID will have a bios setting that will need to be enabled. The links above will help you setup an array.
Cheers'
Mike
Apr 08, 2010 | Asrock P4V88 (P4V88 RAID) Motherboard
Not make instal xp new hard drive "seagate baracuda 7200.12 ST3500418AS, and my motherboard dont see hard for instal
It seems you are saying that the board will not see the new hd.
You need the instructions for the hard drive and the mother board to install the SATA drive.
Some motherboards may need to have the bios upgraded, if it can.
Others are too old.
Sep 26, 2009 | Asrock K7 Upgrade 880 Motherboard
SATA drive not detected
If you will be loading xp on the new drive,You will just need to press F6 during the setup when ask if you want to install 3rd party driver,and follow the instruction and put the SATA driver disk in when ask.(Even during xp setup It will say SCSI device until all the drivers for it are loaded)
May 20, 2009 | Asrock P4V88 (P4V88 RAID) Motherboard
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Asrock P4V88 (P4V88 RAID) Motherboard Logo
265 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
