I have a PVR-9200 with a Sony Bravia TV When connected to the TV scart the volume is reduced by about 60%.If connected to the video scart the sound is OK but volme control and mute button do not work.Any suggestions?
  • 643 Answers
Try connecting the tv with the optical output. also the tv has a volume offset within the menu try turning that all the way up.
Posted on Mar 21, 2011
Need to get a TV channel for PVR viewing. It doesnt appear to be TV channel 0: Lost PVR manual: Help!
Hi
Please connect pvr to tv with a 21 pin scart lead to line input 1 or 2 on tv then when play or menu are selected on pvr tv should auto sw to the selected input and return to tv when pvr is sw off.
regards windyhouse
Apr 02, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Nov 08, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Connecting sony bravia to direct tv
select the correct scart socket used go though the av channels until you find the correct input[scart]
Apr 30, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sound problem
Go into your TV settings and change the Automatic Volume Control Sound Mode. It's probably at Dynamic and the TV is trying to adjust the volume. The popping sound may be caused by static electricity building up on the circuits of your TV or cable.
Does this also happen when you are watching a video/DVD?
Nov 27, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Speaker volume low when set to TV
have you muliple scart leads connected? is everything wired through the tv? is everything wired together? you need 1 scart lead from the tv with enough scart sockets on it to take all your extras.connect your amp through a scart lead aswell.3 things will have to be turned on at all times e.g. tv,sat,amp.Don't connect any 2 extras together e.g. vcr to sat  one will kill the sound from the other
Oct 12, 2007 | Sony STR-DE575 Receiver
Digibox connection
Try looking on the links from a thread on connecting a PVR on bbc.co.uk's POV digital pages
Sep 17, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
