J Deere LX277 has stopped. Engine is running great,,,wont go forward or back...transmission fluid level is good..help
I don't have a John Deere. Had a Wheel Horse once; same problem. There is a transmission switch in back beside the right rear wheel; slides in and out. MAYBE this helps!
Posted on Mar 21, 2011
John deere lx277
make sure if its a hydro drive disengage lever isnt pulled
Oct 03, 2013 | Garden
Vehicle wont go forward
Will it reverse? Checked the transmission fluid level with the car running and engine warm?
Nov 14, 2012 | 1999 Ford Taurus
Transmission is slipping in drive
Wendy,
Have you checked your transmission fluid level? Make sure car is level, engine running with engine and transmission at operating temperature. The dipstick is located under hood, on driver side behind engine. Typically has a yellow handle.
Check that and report back.
Feb 09, 2018 | 1998 Ford Taurus
TRANSMISSION SLIPS AND SHIFTS HARD, AUTOMATIC
Often the cause is low transmission fluid. Follow the instructions in your manual for checking it, because unlike checking your oil level, checking transmission fluid levels require that the vehicle is running.
Please, by no means do this check if you are uncomfortable doing it. Have a "gearhead" friend that you trust or a mechanic show you how.
Most manufacturers ask that you start the car, and while holding down the brake pedal, slowly shift through reverse and then all your forward gears, then place the car back in park.
Next (with the car running- CAREFUL!), find the transmission dipstick under the hood, pull it out, and wipe it off. Put the dipstick back in, pull it out and check the level. If it is low, you need to add some transmission fluid of the type specified by your manual into the dipstick hole (you will need an inexpensive transmission fill funnel), a little at a time, and keep checking it as described above until it is at the FULL mark.
It is important to note that the dipstick is marked FULL HOT (car is warmed up) and FULL COLD (car is NOT warmed up) because transmission fluid expands quite a bit and overfilling is bad for your tranny!
I own a Jeep with a Chrysler "straight six" engine (one of the best motors ever!) and my transmission slipped because of low fluid - I added a bottle of "transmission stop slip and stop leak" fluid to it and topped off the remainder with the proper type of transmission fluid, and now, seven months later, I do not lose any tranny fluid and it shifts great! The stop leak is more expensive, but IMHO it is worth the cost.
Please rate my solution when you get a chance!
VA
Jan 30, 2011 | Plymouth Grand Voyager Cars & Trucks
Transmission
Have you checked the fluid level with the engine running ,and the vehicle in park?If the fluid level is fine,then have the transmission fluid changed,and filter.If this was at all helpful,please rate,thank you.
Jul 17, 2010 | 1998 Ford Taurus
2002 lincoln wont go forward but goes in reverse
Start the engine and allow it to get to operating temperature.
Place the gear selector in Reverse, then slowly through all the forward gears, while holding the brake.
Replace the selector in Park, but leave the engine running.
Check the transmission fluid level.
If low, add fluid until level is correct, then repeat above procedure and check fluid level again to ensure that transmission is filled to proper level.
If level is correct, perform fluid/filter exchange. If problem persists, see qualified service technician for further diagnosis. Transmission damage will require overhaul to repair.
Dec 26, 2009 | 2002 Lincoln LS
John deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Jul 14, 2009 | John Deere Garden
Transmisson question
How about a trans filter change? That works when things like this happen.
Jul 01, 2009 | 1997 Ford Taurus
4x4 won't move!
the transmission is slipping
May 08, 2009 | 1997 GMC Jimmy
Computers & Internet Logo
515 people viewed this question
Alun Cox
David Payne
David Payne
