May I clean my computer contact with your product 4408726 name contact and head cleaner
    Genius:
  • 1,400 Answers
Hello
We do not manufacture or sell or distribute any contact cleaners.
This is a fix it yourself website where we offer advice to help solve problems.
If your going to use a cleaner for your computer i would use compressed air and nothing else.
Read the can carefully before using contact cleaner,as it is usually used for copper or brass or metal electrical contacts.
You may want circut board or electrical cleaner instead.
Posted on Mar 21, 2011
Epson tx700w black ink doesn't printing well.
1st a fall u must purchase original cartridge 2nd clean the head 3rd print the alignment page.
Be careful when u clean the head.
It is better if you use contact cleaner for head cleaner.
IN SHA ALLAH the problem will
Oct 06, 2017 | Epson TX700W Series
Cleaning head and nozzles
Cleaning the Print Head
r_bullet.gifUsing the Head Cleaning utility
r_bullet.gifUsing the control panel buttons
If you find that the printout is unexpectedly faint or some dots are missing, you may be able to solve these problems by cleaning the print head, which ensures that the nozzles are delivering ink properly.
You can clean the print head from your computer using the Head Cleaning utility in the printer software or from this product itself by using the control panel buttons.
  • Print head cleaning uses both color and black inks. To avoid wasting ink, clean the print head only if the copy quality drops (for example, blurred printout, incorrect or missing color.)
  • Use the nozzle check first to confirm that the print head needs to be cleaned. This saves ink.
  • When the Error light is on and a message appears on the LCD panel to prompt you to replace the ink cartridge or to indicate the ink is low, you cannot clean the print head. In this case, replace the appropriate ink cartridge first.
Refer to the appropriate section below to use the Head Cleaning utility.
For Windows
Follow the steps below to clean the print head using the Head Cleaning utility.
r_1.gifMake sure that A4 or Letter size paper is loaded in the sheet feeder.
r_2.gifMake sure that this product is on and the ! Error light is off.
r_3.gifAccess the printer software.r_arrow2.gifAccessing the Printer Software for Windows
r_4.gifClick the Maintenance tab, then click the Head Cleaning button.
r_5.gifFollow the on-screen instructions.
Head cleaning... appears on the LCD panel while this product performs the cleaning cycle.
r_space.gifr_caut.gifCaution:r_space.gifr_space.gifNever turn off this product while Head cleaning... appears on the LCD panel. Doing so may damage this product.
r_6.gifWhen Head cleaning... disappears from the LCD panel, click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Good: print head does not need to be cleaned yet.
Not Good: print head needs to be cleaned.
If the nozzle check page does not print satisfactorily, you may need to repeat the head cleaning and print the nozzle check pattern again. See Cleaning the Print Head.
  • If the copy quality has not improved after repeating this procedure four or five times, turn this product off and leave it alone overnight. Then, perform the nozzle check again and repeat the head cleaning if necessary.
  • If the copy quality still has not improved, one or both of your ink cartridges may be old or damaged and may need to be replaced. To replace an ink cartridge before it is empty, see Replacing an Ink Cartridge. If the copy quality remains a problem after replacing the ink cartridges, contact your dealer.
  • To maintain good copy quality, we recommend copying a few pages at least once every month.
Apr 14, 2013 | Epson Stylus CX6400 All-In-One InkJet...
Tape deck wont accept tape
head may be dirty...May need cleaning....theres a product sold out there that requires that u drop a solution to the head cleaner and insert the head cleaner into the deck...u will need to run the cleaner a few times as if u were playing a regular recorded tape...this process cleans the head...if thats the problem...
Aug 04, 2012 | 1998 Toyota Camry
How to clean heads of my camcorder?
this simple way is to buy this product ( CLICK HERE) ... this is a dry head cleaner .. do not clean it ur self cause you may damage the head ,
do vote if it helps
Apr 02, 2011 | Panasonic Palmcorder PV-DV203 Mini DV...
After several months of being stored i used my roland juno D to find that some of the keys didnt work. I cleaned the rubber contacts etc but they still dont work? and the ones that do are uneven volumes...
Did you clean these contacts with ONLY isoprophyl 99% alcohol and Qtips? If you used another product you may have spoiled the contacts. Also did you clean the circuit board where they contact with the same product?
If you used another cleaner, best to redo your work... quickly... Contact cleaners such as Deoxit and Blue shower destroy this type contact.
Mar 14, 2011 | Roland Juno-D
Print head doesnt move just displaying print head full contact service
Possible the head is clogged and needs a cleaning. Use a cleaner or get tips from the link below:
http://www.inkjet-service.co.uk/print-head-cleaning.html
Feb 17, 2011 | Office Equipment & Supplies
Horizontal lines/missing print occurs on my pages. I have tried to reboot the printer, but the printing issues remain. Do I need to clean the print heads?
Follow these steps to make it work... TIP: Focus on the printer it self. make sure that it can copy (b&w and color) fine.
If your done reseting the printer go to the next step Solution #2 Clean the All-in-One and make a blank copy Before you begin, gather the following materials:
  • Several clean, soft, lint-free cloths
  • Mild glass cleaner
Step one: Clean the scanner glass and lid
  1. Press the power Button to turn off the product, and disconnect the power chord at the back of the printer.
  2. Open the scanner lid, and remove any originals from the scanner glass.
  3. Spray a clean, soft, lint-free cloth with mild glass cleaner.
  4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth.
Step two: Clean the automatic document feeder ADF
  1. If the product is not already off, press the Power button to turn off the product, and disconnect the power cord from the product.
  2. Locate the ADF frame to the left of the white underside of the scanner lid.
  3. Press the ADF frame release.
  4. Unhook and remove the ADF frame.
  5. Lightly dampen a clean, soft, lint-free cloth with a mild glass cleaner.
  6. Use the dampened cloth to clean both sides of the transparent film, and the white strip in the center of the ADF frame.
  7. Clean the ADF frame.
  8. Re-Install the ADF Frame
Step three: Make a blank copy
  1. Remove any originals from the scanner glass.
  2. Load plain white paper in the input tray.
  3. Press Start Copy Black to make a blank copy.
  • If the copy is clean, there is no need to continue troubleshooting.
  • If the copy has vertical bands, lines, or streaks, there might be dust inside the product, poor internal connections, or the product might be damaged. Contact HP's Printers support department @ 1-800-474-6836
To view this steps w/ images click on this link Good luck! :)
Feb 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
Prints with stripes
Your software should have a utility feature named " Head Cleaner "
Please open your software and try cleaning the heads with the option it offers.
May 20, 2010 | Epson Stylus D88 InkJet Photo Printer
Music CDs skipping while playing
yes..if CD cleaner not sucess, you can open the DVD..if you have been done and not working, maybe the optical has been weak..
sorry for my bad english..^_^v
Aug 09, 2007 | Panasonic SCAK410 5-Disc CD Changer
Computers & Internet Logo
David Payne
David Payne
