Question about Braun Health & Beauty
My Braun 5110 gets very hot while charging. - Braun Health & Beauty
Braun trimmer #7526
Most likely, the batteries are dead and need replaced. You need two batteries and they can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-replacement-battery-aa-nimh-p-108.html
For installation videos, see links below
http://www.youtube.com/watch?v=D6jRpCnB8T4
http://www.youtube.com/watch?v=2oAnLpvdYqQ
Jan 09, 2014 | Health & Beauty
When razor is plugged in for charging the whole razor and cord get really hot! What is going on? It is a 4700 Series razor but it says For use only with Braun Series 549 class 2 power units. Do I need to...
After reviewing your Problem , My think says , its a Machine Problem... or may be its a Heat Problem , the Reason of Heating is that , the blade of machine is not installed Correctly , so Blur your Machine , clean it all ,then it will okey.
Jul 24, 2011 | Braun 7000 Series Foil and Cutterblock
Shaver gets hot to the touch when it is charged and ready to use this is a braun 549 series and it just started doing this
Batteries that get hot when charging usually indicate that they are needing replaced. I would guess that your shaver no longer holds a charge as long as it should
You will find compatible batteries for model 7526 at shaveroutlet.com. See link below. You will need to order two
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
See the installation tip on the item page.
You will also find a video that shws how to disassemble the shaver at the link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
Dec 02, 2010 | Braun Syncro 7526 Electric Shaver
My Braun 7526 will no longer clip into the razor for cleaning and charging.
If the arm on the charging stand no longer locks down into place to charge the shaver, you will need to replace the arm or you can replace the entire charging unit. You will find both items at shaveroutlet.com. See links below<br /> <br /> arm only<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html</a><br /> <br /> <br /> complete base<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html</a>
Aug 27, 2010 | Braun Syncro 7526 Electric Shaver
I had my braun 2540 off for along time and I want to charge it again and It doesn't charge. What do I have to do?
my braun 2530 will not charge any more how do I get to charge and get to use this good razor to work again it is too early to throw it out yet- hope to get a useful reply.
preben gerstrøm (gerstroem)
pg2@anarki.dk
Aug 14, 2010 | Braun 2540 S Electric Shaver
Braun 790cc Shaver battery not holding charge
the item has a 2 year warranty. if you have proof of purchase date, you should call Braun for warranty service. Phone number is in your owner manual
Jan 07, 2010 | Braun Health & Beauty
Braun 6520 is not charging after changing the battery board.
there may not be anything wrong with the batteries and circuit board at all. you may have a bad motor
Dec 27, 2009 | Braun Flex Integral 6520 Electric Shaver
The Charging cord's head that fits into the Shaver is broken. How get I get a replacement?
I have several new power charging cords for this model. If you want one Please let me know and will give you a good price.
Nov 13, 2009 | Braun 8585 Electric Shaver
My former razor, Braun 5414 would take 110-240AC as well as 12 DC. Now have Contour 5790, and want to know if itcan also use12 volt DC.
According to the Braun manual for your 5414 Contour, the specs for charging are printed on the electric shaver cord plug. (it's REALLY small print, so I'd get a magnifying lens to look at it!)
There isn't anything in the manual about the multiple voltage for charging the shaver, so I'd have to defer to the Braun (Gillette/Proctor & Gamble) customer service folks to make absolutely certain of what can and can't be used as a charging voltage before trying.
Here's a link to your manual, in case you're missing yours.
http://www.retrevo.com/d/ds/progress?doc=9142c4ae65df1746d12fc67fdc01df52
You can ALSO reach the Braun Customer Service folks by calling them at 1-800-BRAUN 11 (1-800-272-8611)
I hope you find this Very Helpful and best regards!
Oct 06, 2009 | Braun Health & Beauty
Health & Beauty Logo
114 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
