Question about Toys
Why motor burns please give some reasons - Toys
    Problem Solver:
  • 15 Answers
Need a little more detail. What kind of motor are you referring to?
Posted on Mar 21, 2011
Not used for a while while and now got a hot smell from motor
It may be due to the rust formation or contamination on the motor. When you start running it after a while, it heats up to evaporate those contamination. which gives you bad smell.
one more reason could be burning of rotor coil.
Is it burning smell?
Mar 09, 2016 | Washing Machines
94 hyundai scoupe 1.5 non/turbo quit firing after replacing the computer what could be the problem
WHAT COMPUTER DID U REPLACE? WHY DID THE OTHER COMPUTER BURN OUT. THERE MUST BE A PROBLEM IN THE HARNESS CAUSING THE COMPUTER TO BURN UP. COMPUTER DO NOT JUST BURN OUT FOR NO REASON. I SUGGEST TRACKING DOWN THE ISSUE FIRST. GIVE ME MORE DETAILS AND i WILL BE ABLE TO TELL YOU WHAT NEEDS TO BE CHECKED .
Mar 15, 2013 | Hyundai Motor 1994 Scoupe
Ihave no power to my sony tc-w365
The power supply would have to be examined and the problem may be a burned out regulator or as simple as a thermal broken solder joint. One reason the power supply gives out is due to worn out capstan motors that are drawing too much current- the speed of the deck can give indication of this. There is sometimes noise that comes from DC motors with worn brushes- the brushes get to the point that they wear through and break off0- that is when they make noise. New motors are available.
Feb 17, 2013 | Sony Dual-Deck Cassette Player/Recorder...
My heater only works on the high setting, and when you turn it on high it makes a loud grinding noise. i live in Maine and its coooooooooooooooold. please help.
Hello Otis.
The blower speed system on your car goes through a resistor to give various speeds.
The reason it still works on high is that on high it doesn't go through that resistor.
because you mentioned the blower is noisy it leads me to believe the motor is the reason for the resistor burnout.
When the motor begins to go bad it draws more electrical amperage. The resistor can't handle it and burns out.
Both will need to be replaced, that I am sure.
They are mounted above where the passengers feet would be behind a panel that will need to be removed.
Relatively easy job if you are young and flexible enough to get under there and work.
Both parts should be available through your favorite auto supplier.
I prefer the Delco branded replacement parts because they fit and the motor comes with a new fan.
I hope your repair goes well. Keep warm!
Thank you for using FixYa.
KL
Jan 09, 2011 | 1999 Buick Century
Hello can you help me please? I have a Kirby G4 vacuum cleaner, It did work ok until it started to give off burning smell and lots of sparks from the brushes. I have changed these brushes, the motor still...
Some debris, even sand or dirt, probably got into the motor, causing damage to the armature. If this is the case, you will need to replace the motor. The burning smell from the motor is generally a sure sign of a bad motor.
Jan 02, 2011 | Kirby G4 Bagged Upright Vacuum
I have a Kenwood Major mixer that gives off smoke an electrical burning smell from the motor when running. Is it worth repairing?
hi its not necessarily the motor but could be some capacitors on the speed control unit ( the control knob is attached to it) spares are reasonable to buy .you can find a dealer from kenwood.co.uk website..
Nov 19, 2010 | Kenwood KM800 Major Classic Stand Mixer
Not washing
The reason to this problem can be due to two reasons.
It may be either the burn spot or burn fuse on the motor
control board.
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a Ruud Acheiver 90, I'm having some problems, the rollout (burner) limit switches are opening, and there is an electrical burning smell. It seems that sometimes the squirrel cage isn't kicking on,...
Thanks for your question,
yup your fan motor is bad, if you need to manually start it each time then the motor winding are bad and it is not getting the air across the coils, which in turn are over heating, thus causing a burning smell, and then tripping your limits, you need to replace this motor ASAP, before it does cause a fire, if the limits ever fail !! I hope this was helpful for ya, if it was please give this a rating, thanks again,
mr.grzz
Jan 23, 2009 | Heating & Cooling
Motor is burned out
Are you sure the motor is bad?
Dec 03, 2008 | Hobart H600 Stand Mixer
Toys Logo
32 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
