Question about GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
My unit is 6 years old and just stop cooling, both sides. I can hear a fan but no cooling.
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 21, 2011
When I open the fridge door I can hear the fan slow to a stop. This just started a few days ago, before that we never heard the fan
It could be the fan motor is starting to go bad. It eventually get to where the cooling will be affected.
Sep 12, 2014 | Refrigerators
Window unit (110) cools for a few minutes then stops cooling just fan air unit is about 6 0r 7 years old
It sounds like your compresssor is shutting off on an overload. After the overload cools down the compressor comes back on until the overload heats up and shuts the compressor off again.The fan keeps running as it is not on the same circuit as your compressor.
Aug 02, 2011 | Carrier YC273D Air Conditioner Window/Wall
2 year old side by side refrigerator & freeze stopped working. Neither side will cool. Model # 106.55122700 manufactored 6/2007. No pool of water, etc.
Is the machine turned on and can you hear it running??
If nothing is running then it could be a defective cold control (thermostat) or the machine went into a defrost mode and failed there. If it is running then.....
Open the freezer door and you should hear a fan motor running.
If not the fan motor is defective and needs replaced.
Look to see if there is frost building up on the back panel in the freezer section. If you see a buildup, then the defrost system needs repaired.
There is another fan motor located in the machine section behind the cover on the back rear of the fridge. It must be running as well.
If none of these items check bad, then you could well have a failed sealed system, including the compressor.
The sealed system carries a 5 year warrant. Call your selling dealer for service.
Nov 03, 2009 | GALAXY Microsystems 25.4 cu. ft....
Have 2 year old Frigidaire FAH105N1T Air Conditioner. Fan stopped working on fan or cool. Serviced twice and they said fan needed to be oiled. Worked 3 weeks then they said it needed fan motor. Bought new...
it possible to replace the defective as follow:
1- take out the unit
2- remove the top cover
3- try to take out the wires from there connections and note each color to witch connection
4- loose bolt of indoor blower to the shaft
5- open the bolt of the condenser fan to the other end of motor shaft and take out the fan
6- open the fixation nuts or bolts of the motor then slide it outside.
7 replace as take care about witch side of shaft is for blower or fan.
Sep 06, 2009 | Heating & Cooling
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Freezer and Refrigerator won't get cold.
Slide unit out from wall and lower temp setting and feel if compressor is running. If it is the Freon has escaped. Best bet call a repair company.
Feb 02, 2018 | Refrigerators
Suddenly stopped cooling
Sounds to me like the run capacitor is bad. It is a dual one which means runs the fan and the compressor. No big deal capacitors are only 10 bucks and easy to replace.
First turn off the electricity to unit at breaker would be best. Next after you open the access panel locate the capacitor and make a note which wires go where one side is marked fan the other is herm. in the middle is comm. Take the old one in and get a new one same size and reinstall. Now parts only have one year warranty but they should have a discount on a person that bought a unit from them if you talk to them and tell them how can this happen only 2 years old. you know the story they might just throw one in for free to keep good business practice. Let me know how it goes. ken
Apr 16, 2009 | Intertherm P3RA-060K Air Conditioner
Not cooling/freezing THERMADOR SIDE BY SIDE REFRIDGERATOR BUILT IN
Sounds like thatyou refrigerator has leaked out the refrigerant. If you have a condenser i.e. cage on the back , place your hand over it and see if it is warm if it is not then if deffinaltey the gas.
this is not a diy job and you will need an engineer with relevant qualifications..
hope this helps
cheers wash doctor
Aug 25, 2008 | Refrigerators
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
RS21 DCNS FRIDGE COOLING FAULT
There is a fan behind the plastic. This distributes the cold air throughout the fridge. What happens is this fan stops turning due to freezing up. A temp solution is to unplug the samsung for 6-12 hours to allow the ice to melt from around the fan. This is a known design fault. It is easy to dismantle the plastic cover and defrost the frozen fan with a hair dryer, this way the fridge will only be off for about an hour
Aug 14, 2007 | Samsung RS2630SH Side by Side Refrigerator
GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
44 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
