Question about RC Keecat 65 Bobcat 55.1'' Nitro R/c Rc Airplane Rc Plane
I just bought a brand new Rich Model Keecat with a os 61 engine, but it didn't have a manual, to properly set it up, I need to know where to install the Receivers, batery and the gas tank, as well as where is the CG. I love this aircraft and want to set it uop properly. Thanks
How do you thread it
Google make,model,manual perhaps you will find what you need
Apr 13, 2016 | Sewing Machines
How do Setup a password for my router already have one password need to set a password for guest
You need to use your browser to log in to your router. Locate the guest account in the menu and set a new password. If you'd like, many routers allow you to disable guest accounts entirely. If you need specific step-by-step instructions, I need to know what brand and model router you are using, what OS your computer has, and what browser you use for accessing the internet.
Dec 26, 2014 | Computers & Internet
Base plate screw size Toshiba 50"
To know about the screw size, you have to download its repair manual by internet. It has disassembly details of the set, and have details about all screws and other stand parts. If you wish to get some details about these, check the site linked here. It has disassembly procedure illustrated to many brand TVs. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Jul 18, 2013 | Televison & Video
I bought my packard bell easynote i cant do anyting because it when i try to find the driver it just say standar VGA card , the camera dont even work. what can i do ? can i download/find these...
> I bought my Packard Bell EasyNote.
From which store?
The preinstalled copy of Windows should have the correct device-drivers for the camera & video-card.
Reinstall Windows, from the supplied "System Recovery" set of CD/DVD disks,
to reload those device-drivers.
Or, if it brand-new, take it back to where you bought it, and exchange it.
Jun 08, 2011 | Computers & Internet
Hi, I have a sony vaio laptop, model PCG_3E2L. It's start up windows was vista home premium. Last night i change my windows. Properly i have changed my windows. But my webcam & touch volume option...
Ur right about it! When changing ur OS, u have to get new drivers for ur mo board and utilities( Audio, video, Network Lan, USB, and upgraded Bios).
Better go to Sony Vaio and download the drivers for the new OS!
May 11, 2011 | Computers & Internet
Looking for assembly manual for keecat 65 rc
If you email the manufacturer on the link below they will email you a coppy of the manual.
Here's the manufacturer
http://www.avia-richmodel.com/index1_1.html
email address at the bottom of the page.
Apr 01, 2011 | RC Keecat 65 Bobcat 55.1'' Nitro R/c Rc...
How do I adjustment the carb on an almost brand new weed trimmer?
The H is for high rpm (Main mixture) and the L is for Low rpm (Idle Mixture). First turn in both screws all the way in and then turn them both out 1 and a half turns. Pump the primer bulb if the equipment has one. Start the engine, once it is idling, turn the L (Idle Mixture) screw out (counterclockwise) from the preliminary setting until the engine speed decreases (rich). Note the position of the needle. Now turn the adjusting needle in (clockwise). The engine speed may increase, then it will decrease as the needle is turned in (lean). Note the position of the needle. Set the adjusting needle midway between the rich and lean settings as in the picture below. Don't touch the throttle during this procedure. Once you have found the best idle speed for the engine then you need to adjust the high rpm. This process is the same as with the idle rpm process but you need the to hold the throttle wide open while you are adjusting the H (Main Mixture) needle on the carburetor.
May 03, 2009 | Poulan Garden
Screen resolution will not change since new computer has benn installed
check if your video card driver is installed properly. you need the driver installed before you can change your display resolution.
to check if driver is installed on WinXP (let me know if you are using diff. OS:
right click My Computer - Properties - Hardware - Device Manager
click the + sign on Display adapters. if you don't see your video card brand and model, you need to install your video card driver.
Apr 25, 2009 | Computers & Internet
D61w20 big screen tv
You will need the service manual to be able to properly align the new tube after installation, that will also give you important info such as discharging the old tube as well as removal instructions. Post the chassis number on your set and I can post the link to get a good service manual if you would like. rca are crossed by chassis number that should be located on the tag next to the model number
Mar 20, 2008 | RCA D61W20 61" Rear Projection Television
SCSI and IDE HDs, can they work together?
This next solution is viable in win 98, and I don?t see any reason why it shouldn?t work for you too. If you know of anything I?m missing you should consult someone else. The solution is slightly complex, so I hope I can explain it properly: 1. Create a startup disk so you can format and install windows. 2. Set the new HD as master and connect it to Primary IDE. 3. Disconnect the SCSI and remove it. 4. Restart the computer with the disk you created (with the new HD connected). 5. Go to the Bios settings in order to make sure that the computer does recognize the new HD as the primary drive in the first IDE. 6. Now, FDisk the new HD, set the partitions, restart and format it. Install the OS and make sure it is working properly. 7. Insert the SCSI and restart again. 8. At this stage the computer would reboot into the IDE and see the SCSI/ You may have to change something in the OS settings for that, but I don?t know where. Good luck.
Feb 22, 2006 | Adaptec SCSI 29160 POWERDOMAIN MAC KIT...
RC Keecat 65 Bobcat 55.1'' Nitro R/c Rc Airplane Rc Plane Logo
109 people viewed this question
Top RC Toys Experts
LP
Tom Chichester
Kevin K.
Are you a RC Toy Expert? Answer questions, earn points and help others
