Brand new printer just installed 5 minutes ago. Paper is jamming on every feed. Is there a possibility that the rollers are not ggod and I have to bring the printer back where I bought it?
    Genius:
  • 1,089 Answers
Doesn't matter what is good or bad. It is a brand new printer, don't void the warranty.
Pack it up and bring it back.
Get it exchanged for one that works.
Posted on Mar 22, 2011
Error paper jam
Hello Cassandra,
It sounds like you are having phantom paper jams. When the printer starts a print job and tries to pull a piece of paper but can't grab it the printer thinks there is a jam but there really is not. If the paper pickup rollers are worn down they are not able to grab the paper correctly to feed it into the printer which causes this type of error. The rollers are considered user installable and come in a kit with the rollers and the paper separation pad which keeps more than one paper from being pickup up at the same time. Installing the paper feed kit should clear up your paper feed problems. The paper feed kit is available here: http://www.ccl-la.com/catalog/product_info.php?products_id=342
I hope this helps.
BuddyMc
Aug 06, 2013 | HP CP3525N Color LaserJet Printer
OKI C9600 paper jam problems: Paper jams continually, either on first attempt to printing or if it prints a page the 2nd page inevitably jams. Printer has only done 1500 pages since new ,and i have removed...
Wow! That's quite the printer you have there. The C9600 does have a feed roller in the front; and it's not uncommon for paper to still get stuck. Does your paper "fan" when it goes through; or simply, go through and jam? It's possible a paper feed sensor is bad too. Another thing you might want to check is the paper tray; and that the paper is set to the proper size.
Also be aware, the OKI 9600 had a recall a year or so ago for some potential "shock issues" I would advise you to check with OKI directly to determine if this printer is part of that issue too.
Jan 04, 2011 | Office Equipment & Supplies
Paper jammed in printer. Thought I got it out but new paper just curls and jams too
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Sep 30, 2009 | Lexmark X4650 InkJet Printer
Paper will not feed on my MFC3420C
Jan 20, 2009 | Brother MFC-3420C Printer
My brand new X5340 printer shows there is a paper jam but there isn't one. The one and only sheet it has printed was the test page. Since then, I have been unable to get rid of the "clear paper jam"...
Good luck...
Dec 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Printer had paper jam
Dec 06, 2008 | HP Deskjet 6940 InkJet Printer
Paper jammed in area 5. Removed #6 and started to pull paper out, but it tore and will not release the remaining part.
Nov 11, 2008 | HP Officejet Pro L7680 All-In-One Printer
Paper Jam Error
Good luck...
Sep 04, 2008 | HP Photosmart 8750 InkJet Printer
Brand new Lexmark X4270 All-in-one, won't copy, fax, or print
If this not work i guess your printer is defective get it replaced>>>
Mar 17, 2008 | Lexmark X4270 All-In-One InkJet Printer
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
16 people viewed this question
jasbo
jasbo
