Question about Dishwashers
The problem is the glasses are very foggy and spotted is there a certain detergent I should use?
  • Dishwashers Master
  • 3,247 Answers
Without knowing the make and model of your dishwasher, I can only suggest you first check if the Rinse aid is there and try to change the dose if your dishwasher can allow you to adjust this. Use the detergent recommended in the dishwasher manual.
Posted on Mar 21, 2011
My glasses look foggy and white after they are cleaned
Too much detergent; no rinsing well; hard water... There is an acid wash to revamp glasses/ you'd need to google it...
Feb 27, 2014 | KitchenAid 24 in. KUDS01FLSS Built-In...
Foggy glass
The seal on the microwave door glass is compromised and allowing moisture and perhaps the microwaves, to enter between the windows inner and outer.
There is a great potential for leakage here.
I would not continue to operate this oven until I have it fixed.
Jan 30, 2014 | AEG Microwave Ovens
Why are my glasses foggy? It looks permanent. Probably damaged.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Apr 24, 2011 | Maytag Dishwasher
Glasses come out foggy dishes don't look completely clean
heatman101
Mar 10, 2011 | KitchenAid Dishwashers
Glasses /cups/dishes on the top rack don't get clean. they come out foggy, although I use Jet Dry daily
If you have hard water glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Feb 24, 2011 | Westinghouse 24 in. MDB121 RF Built-in...
Right after 1 year, now there is a white film on all the glasses and bad spots, that rubs off if you wipe it fresh out of the dishwasher. Yes, we are using rinse aid.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Dec 04, 2010 | Whirlpool 24" Black BuiltIn Dishwasher...
Soap dispenser doesn't open during the cycle glasses often come out looking foggy
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 04, 2010 | Bosch Dishwashers
The machine does not seem to rinse properly. We have checked the water fill level, water temperature, spray arms are not clogged, have determined it is not a hard water problem and have tried Glass Magic...
Sep 23, 2010 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
Foggy patch on scanned images, C4180
you can use liquid detergent and wipe it with an old news paper. you also need to remove first the glass so u can also clean the other side
Sep 26, 2008 | HP Photosmart C4180 All-In-One InkJet...
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
