Question about AquaBrew TE-1216 Coffee Maker
We have an AquaBrew TE-1216, and the valve on the hot water dispenser started leaking (flooding our counter top). Are there replacement parts for this? Carla
    New Friend:
Hi Carla,
I'm assuming there are. I bought parts for ours when some fittings began leaking after the unit was moved. The company has changed their name but it is the same company as attested to by their support team. and the devices are still supported. http://www.cafejo.com/ ">
Posted on Apr 14, 2014
  • morecoffee70
    morecoffee70 Apr 14, 2014
    Hi Carla,
    I'm assuming there are. I bought parts for ours when some fittings began leaking after the unit was moved. The company has changed their name but it is the same company as attested to by their support team. and the devices are still supported. http://www.cafejo.com/ Makers of Fine Brewers and Coffee
3 Suggested Answers
  • 1206 Answers
SOURCE: Leaking Radiator
you can try tightening it first but yes it just has an o ring around it that is easily purchased at any auto parts and easy to install but antifreeze will have to come out,or you also can buy a whole other drain plug and try to remove and replace it fast as not to loose much coolant with out having to drain the system. good luck hope this helps you.
Posted on Feb 02, 2010
SOURCE: Samsung WF218AN washing machine is leaking from the soap dispenser
Simple sugestion, try cutting back the water in flow rate from the taps, If this works, unscrew the hose from the tap and fit a stainless washer with a small hole in the inside, on top of the wire mesh water filter on the inlet pipe to restrict the flow. Hope it helps.
Posted on Dec 01, 2011
Hello. My G.E. Monogram water dispenser trickles water after we get water from it. We have to keep a cup there to catch the excess water. How do I fix it so it stops as soon as we get water out of t
Try replacing the Water Valve. It is located in the back of the refrigerater, left side. You should see three tubes connected to it. This part fixes the following symptoms - Leaking water, Water dispenser will not dispense water, Ice maker will not make ice and Ice maker won't dispense ice. GE part#WR57X10032. The Water Valve is extreemly easy to replace. Only takes about 15 mins total time to remove, install and confirm. I just replaced mines..my problem went from leaking water to no water was dispensing at all. I have the GE Profile, it uses the same water valve as your GE Monogram. There is a You Tub video that also shows how to replace. Good Luck!
Dec 27, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Leaking water tank on Insinkerator hot water dispenser
Jan 2013
1) If the tank is leaking, then Replace with new dispenser.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
2) Add comment and attach photo of leak.
Jan 23, 2013 | Emerson InSinkErator W-152 Hot Water...
I work at a church that is using the AquaBrew TE1216 coffee brewer, but no one can find the manual for it (it's been here for several years). Right now, the bottom red light for the water quality indicator...
These brewers have a timer system in them based on (I think) a 6 month timer. The LED is not an indicator of actual water quality - it is just a reminder to change your filter every 6 months. To reset it, loosen the screw on the top cover and lift the top off. You will see a push button on one of the circuit boards. Hold the button in for several seconds and the timer should reset. Also should check the 9V battery and possibly change it while you are in there.
Feb 07, 2011 | AquaBrew TE-1216 Coffee Maker
I am unable to use the Bellagio water cooler now as the cold water dispenser is leaking. There is a constant drip so I had to remove the water bottle, then drain all the water from the reservoir. I have...
Go to www.super-electric.com and send them a message about your problem. They have parts. I can't tell you if they will help you or not, I have just emailed them today as well. I have both sides of my 1 year old water cooler leaking, model W074DRF11BQD. (from Zellers) I have hardwood floors and I would rather throw this unit away than risk water damage. If anyone is reading this and thinking of purchasing one of these Bellagio water coolers, spend your money elsewhere - THEY LEAK!. My husband is very handy and has just spent 2 hours on it with NO success. The parts are defective - this unit is NOT full of complex working parts. One plastic part causes pressure on the valve and causes a leak(s). After light usage and nothing damaging it, 8 months old one side went and the other side has been leaking for a couple of days and we are just coming up to a year. If anyone else had this problem and fixed it, I would love to hear the solution.
Dec 26, 2010 | Microwave Ovens
After cycle, water is in the softener and bleach
Water floods the dispenser compartments at the start of the cycle to dilute/dissolve the softener, bleach, and detergent. The reason why water is in the compartment after the cycle is that, the detergent, the softener, and/or the bleach does not flow into the tub properly. It's either the dispenser assembly is clogged or excessive amount of detergent, softener or bleach is used. Clean the dispenser assembly and make sure to use no more than two tablespoons of powdered HE detergent or one-and-a-half ounces if liquid HE detergent.
  1. Unscrew the two screws on the back of the top plate then pull it back then upward.
  2. Pull out the dispenser drawer.
  3. Unscrew the two screws then push the dispenser assembly out.
  4. Unscrew the nut at the lower part of the dispenser.
  5. Remove the four connectors from the valves.
  6. Unscrew the two screws from the back of the cabinet.
  7. Reinstall the dispenser assembly in reverse order.
Dec 30, 2009 | LG WM-2277HW Front Load Washer
Whirlpool 9100 lw2: water does not shut-off, i have to shut off water valves on hot & cold side after each use. The latest problem is the water did not shut off at all & flooded the laundry room.
your water mixing valves are leaking by
this is a very easy repair
three screws keep the top down on the back
slide the top backwards then lift
the water valve is right there on the back wall
call apliance parts pro
877-477-7278
order part number AP3128776
41.00 a few dollars cheaper than sears
Oct 14, 2009 | Whirlpool GHW9100L Front Load Washer
Kenmore 24632 leaks water from right rear corner
The problem may be attributed to either a leaking water inlet valve, or the associated internal hoses that run from the valve to the dispenser. The following link explains how to access the inside of the washer and/or replace the valve (if required):
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
If parts are required, you can purchase from any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop all of them for the best deals.
If you have any questions abou this repair, or require additional assistance, please let me know. I hope you find this helpful.
Jul 30, 2009 | Kenmore 24632 Top Load Washer
Washer Tub Fills With Water When Washer is Not On
I suspect you have a water inlet valve problem. When the valves fail, they tend to either leak by, or do not open at all. The symptom you are describing is typical of an inlet valve that is not closing properly. The leak may be minute, but over time, it fills the tub and over flows. To access the water inlet valve, you will need to remove the washer top panel. Remove the three screws in the back that hold the top in place and slide the panel straight back and lift off. The water inlet valve will be located on the left hand side in the rear between the fill hoses and the dispenser (as viewed from the front of the washer). If you wish to perform this repair yourself, you can find the part at searspartsdirect.com. Just type in your complete model number and the part can be located on the next page under the "Dispenser Parts" section as item number one (part #8181694). The replacement process is very simple. Just turn off the water source, remove the fill hoses, the dispenser hose and the mounting screws. If you need further assistance, please let me know. I hope this helps you.
Jul 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Water Leak
Have you found a solution to your problem? We started having a a similar problem with our Frigidaire. Thank you.
Jun 18, 2007 | Frigidaire PHSC39EESS Stainless Steel Side...
AquaBrew TE-1216 Coffee Maker Logo
73 people viewed this question
Top AquaBrew Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you an AquaBrew Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
