The paper keeps jamming in my new printer . I have read and reread the instructions and followed them carefully, but it keeps happening. I need this printer for my childcare business and it just won't work! Help!
    Problem Solver:
  • 15 Answers
If it's a new printer, I think you should take it back and swap it for another one. If you are following all of the instructions, and are using the right paper you shouldn't be having this issue. It sounds like a faulty printer.
Posted on Mar 21, 2011
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
LexMark 5400 Series All-In-One Printer
To clear a paper jam:
  • Pull Carefully
    If the sheet of paper is visible at the output slot of the printer (in other word, it stopped on its way out of the printer), try pulling carefully on it. If it pulls smoothly and easily, then carefully pull it the rest of the way out. If there is resistance, then stop and go on to the next step.
  • Open the Cover
    Open the printer cover and wait (in the case of an inkjet printer) for the carriage to stop moving. Carefully, slowly pull out any paper that is caught there.
  • Take Care
    Do NOT pull paper out from where it was feeding into the printer (where the blank paper enters the device). The rollers on your printer may only go in one direction, and if you force them the wrong way, you could damage the machine.
Be careful of the following:
  • Laser Printers
    If you have a laser printer, be very careful when pulling out the paper -- laser printers can get hot.
  • Paper Shreds
    If any paper tore, either during the jam or while you were removing them, remove any appliances that you can (paper trays, etc.) and look for the shreds of paper. Try to make sure nothing has been left behind.
If you have frequent paper jams:
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
Goodluck..
Feb 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
When printing documents no matter how few or how many pages, paper gets stuck in the middle of printing.
Try using regular paper on unit as specified by Samsung. If that does not resolve the issue then the hassle lies with the paper feed mechanism. Often a good cleaning of all the rollers in the path can take care of the issue.
Aug 24, 2015 | Samsung ML 2525 BW laser Printer
How to remove paper jam from duplex unit
No issues i share a informative links please visit and read it.
Read more help... How to fix printer paper jam andHP Printer Support
Thanks,
Aug 26, 2014 | Ricoh Aficio SP C820DN Laser Printer
My brand new 800xp won't do anything just says jammed paper & I just plugged it in
I suggest you return it to the shop and ask for a replacement printer as it is covered by warranty. Do not try to fix it because you most likely will void your warranty.
Dec 05, 2012 | Epson Artisan 800 All-In-One InkJet...
Paper jam error without a paper jam
sometimes the printer keeps telling you one thing first you have to read again your instruction carefully or sometimes its just the position of your printer where the paper was
Apr 17, 2012 | Office Equipment & Supplies
Paper jam
Follow this procedure:
  • switch off printer
  • open printer case
  • carefully remove all paper that got stuck, take care you don't damage anything inside
  • close printer case
  • switch on again
More detailed instruction can be given after you tell us the printer model and what you did before the paper jam occurred.
Oct 21, 2010 | Office Equipment & Supplies
Paper jam on hpc7280 printer noise from duplexer area NO PAPER JAM
Follow the instructions in this video. If you follow those instructions and still get the message, you may need to replace your printer or the rear door.
May 19, 2009 | HP Photosmart C7280 Printer
k24674
jasbo
jasbo
