Question about Panasonic Lands Phones
I have a Panasonic KX-T2345 and I need Info on programing memory stations and using "call hunt". Thanks
  • 3 Answers
PanasonicKX-T2345 program buttons
To Program
Push Buttons
1 Memory slide Sw Under
Lower RT lip to Program
2 Memory light lit
3 Station button Press (Beep)
May want to write name 1st
4 Memory light goes out
5 Dial Phone number
6 Memory button Press
(Long Beep)
7 Memory light lit
...repeat 3-7 for more Ph #
8 Memory slide Sw Under
Lower RT lip to Set You are Done
PanasonicKX-T2345
Posted on Nov 01, 2014
doctox
  • 51 Answers
SOURCE: Transfering incoming phone calls Mod. Panasonic KX-T7730
do you mean call divert?
its possible.
we could do it.
Posted on Jan 17, 2008
SOURCE: Need Instructions for Panasonic Easa Phone Model KX-T2220
How can I retrieve my messages from home when I'm some where else.
Posted on Jun 20, 2008
checkitright
  • 1362 Answers
SOURCE: KX-T7730 programming manual
http://www.retrevo.com/
Posted on Aug 07, 2008
SOURCE: dear Sir,,, plz i need
I need to program date & time. I also need to add voice message (office Hours & after office hours)
Posted on Nov 24, 2008
SOURCE: "Panasonic phone Model no.KX-TSC35MXW DIAL
how i can solve the restraction of calls
Posted on May 03, 2011
Panasonic KX-TCD25AX cordless phone. Why can't it find the base station?
several reasons
too far away from the base station
too much interference between the phone and the base station ( buildings, iron sheeting etc)
the phone is not programmed into the base station memory-- re do the system program where the base station recognizes each phone and sets it's number for identification
May 14, 2015 | Panasonic Lands Phones
I have Panasonic kx-T7453 and one of the Outside lines was already connected to a station and while programming a One-Touch dialing ended causing the outside line to be disconnected to this station. How do...
In a TD system, the lines have 2 digit number 01-12 normally, up to 55 actually. So, if line 1 is missing, press PROGRAM dial 99 press the unprogrammed button and dial 0 01 STORE
Press PROGRAM or pick up the handset and drop it back down to exit programming.
Carl
Apr 21, 2011 | Panasonic KX-T7453 Corded Phone
I am using Panasonic KX-T7730 i could not make out going calls wich strarts by " 0 " i change my phone but the problem is still there My extension number is 114 we are using pbx system
Is your extension programmed to allow dial 0 calls? The phone is just an instrument, it has no programming. Guess where the program is and who controls it? Yep, see your system administrator.
Carl
Apr 14, 2011 | Panasonic KX-T7730 Corded Phone
When i pickup the phone i want the intercom to be my first option not a line out?
One of the following two methods of programming "Preferred Line Assignment-Outgoing" should work depending on which Panasonic phone system your KX-T7433B phone is connected to. Try number one first, if PROGRAM 99 does not get you into station programming, try number 2.
1) Press PROGRAM button then dial 99 to enter station programming. Dial 1, then press INTERCOM button to select Intercom as your Preferred Line Assignment-Outgoing choice. Press AUTODIAL/STORE button to save programming. Press PROGRAM button to end station programming or lifthandset then replace in cradle to end station programming.
2) Press PROGRAM button then dial 19, press AUTODIAL/STORE button. Press INTERCOM button then AUTODIAL/STORE button. Press PROGRAM button to end station programming or lift handset and replace in cradle to end station programming.
Feb 11, 2011 | Panasonic KX-T7433B Corded Phone
I have a KX-TG5672, need info on whether this system is operable. Have it for 3-4 years; bought at Best Buy , never used don't remember why ; tried to return with no success. Other Radio Shack equipment...
Hi.
The KX-TG5672 can be used with any working landline network in its country of purchase. Unless the phone has been programmed, the phone is not subject to any line restriction.
Here the full user manual: KX-TG5672
Dec 13, 2010 | Panasonic KX-TG5672 Twin Cordless Phone
If I call an extension and they don't answer how do I program the phone so that I can leave that person a message? I'm using Panasonic KX-T7453 Thanks Chris
Press the MESSAGE button. It will light the lamp on the receiving station and when they press MESSAGE it will show that you called.
If you're trying to program "voice mail", then there are specific instructions to setting Call Forward No Answer or just dialing into the VM sytsem and dialing #6 and their extension to leave a direct message.
Carl
Dec 01, 2010 | Panasonic KX-T7453 Corded Phone
How to program telephone numbers in memory?
Your phone (KX-TC911-B) can store up to 10 phone numbers. Numbers 0 - 10 are your memory stations.
1. Make sure the TALK indicator light is off.
2.Press Program. The TALK indicator light will start flashing.
3. Enter the phone number.
4. Press AUTO.
5. Press a memory station where you want to store a particular phone number.
6. You will hear a confirmation tone. 1 beep means the number has been successfully stored.
2 beeps mean, you entered the same number that has already been previously stored.
Click on the link if you would like to have a pdf copy of the manual/tutorials.
Jun 24, 2009 | Panasonic KX TC911B Cordless Phone
Trouble with the display
Hi Mary
Which system are you using?
If you are using panasonic kx td 1232 then just press the * key keeping the handset on hook.
If you are using a panasonic kx tda system then just press the transfer button keeping the handset onhook.
To change the date you will need to goin the program mode by pressing the Program button followed by *# 1234. then it will show on the display sys pgm no : enter 000 and press autodial or enter. Then you can change the date.
Aug 08, 2008 | Panasonic KX-T7453 Corded Phone
Dec 07, 2007 | Panasonic KX-TG2431 Cordless Phone
Lands Phones Logo
278 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
