Question about Bosch Washing Machines
A sheet got caught in the rubber gasket around door and the metal ring came off. We put it back together and now the machine won't drain or agitate. Do you think the belt came off or is something blocking the drain plug and that is why it isn't draining or spinning?
  • 643 Answers
Remove ring and gasket. check for any blockage. reseat and try again.
Posted on Mar 21, 2011
Gasket replacement problem, Hotpoint WMF540 washing machine
most I have ever seen have slots in the sheet metal that tabs fit into like slide loc tabs.. this requires sliding the face up or down on the sides.. that may help..these are locked by internal screws that you can take out from tne inside ..
Jan 12, 2014 | Washing Machines
Rubber seal has come off and cannot get the metal ring back on to tighten the seal back. Any suggestions on how to do this.
You will need to stretch the metal ring a bit. Once stretched make sure to shape in a circle again. Using two screw drivers and two pair of hands pull the metal ring back around the gasket. It is a real pain to do, but can be done. Make sure that the spring is located at the bottom of the rubber gasket. I'm sure that they make a special tool to do this, but this worked for us and washer still works fine.
Nov 17, 2010 | Bosch Nexxt 300 Series WFMC2201UC
When moving a whirlpool washing machine (Model AWM 1000) a large thin metal ring (spring-loaded at one end) came out. Where does it go to refit it and how do I refit it? On the machine there's a groove...
It goes to the outer lip of the door opening where the groove is to secure the door gasket. It definitely serve such purpose, not for nothing.
Oct 13, 2010 | Washing Machines
Clothes get caught under the agitator and tangled around the agitator and have to unravel the clothes from the agitator
Check the rubber gasket around the agitator is not worn. If it is get a replacement and insert it in snugy.
Aug 16, 2010 | Whirlpool LSQ8543J
The rubber in front of the machine has come out so has the metal spring that goes around it
take lid off put rubber back in place and put the metal holder around the rubber with screw loose try have the clip connection to the top as this helps with tightening. tighten screw and jobs a good un
Jun 23, 2009 | GE WSXH208A Front Load Washer
The rubber gasket around the tub fell off on front loader
Open the door and reinstall the bellows (door gasket) onto the door lip. The metal ring clamps the bellows to the door lip. Start in the groove at the top and work your way down the sides. The spring part goes on the bottom (be careful not to stretch it too much). An extra pair of hands could help.
Let me know if you need more assistance.
Apr 02, 2009 | GE Washing Machines
Kenmore elite duet 410 metal wire for gasket came off
is it a metal wire connected at bottom with a 2-3inch spring???? is so it secures the "bellow to the front lip of the machine. youlll need to stretch it over the front "bellow lip after installing the "bellow"
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Final Spin Cycle Not Working
I unclogged the pump, it was really easy, and it fixed my problem (I have no mechanical know how)! let me explain how I did it!  I have the Frigidaire Front loader for two years, it was acting funny, wouldn't spin, wouldn't drain. My solution was quick and simple, per a solution already mentioned on this site.  In short, The rubber drain was clogged.  There were two cotton breast pads, that must have been in there for months.  Recently my washing machine would not drain, and therefore wouldn't even think about spinning fast.  To unclog, first take off the front bottom panel.  (There are two tight screws on the front bottom, next to the floor, I had to use a powerdrill to remove them, and tilt the machine against the wall to get to them).  Next, there was a black rubber accordian on the front right, where the water drains.  (remeber to unplug your washing machine, to avoid any shock or such!)  I simply unscrewed the big metal ring, (I think it's called a gasket). After unscrewing the metal ring, I could easily pull the rubber accordian down 2 inches, stick my hand in it, and pull out debris.  I pulled out debris for about 5 minutes, and was so excited because I knew my washer would work great again.  I simply put the rubber accordian part back on the lip, screwed the ring piece pretty tight. I used a towel to absorb a small amount of water, that got inside the washing machine.  Now, it is spinning a million miles per hour again.  I will put the rectangular bottom front panel back on in a few days, I just want to double check, there is no leak, which there is no reason to suspect, as removing and putting the metal ring back on was easy!.
Dec 10, 2008 | Frigidaire GLTF2940ES Front Load Washer
Softener
that cap has a rubber o-ring at the edge. it covers the nut so that no liquid would be spilling on the metal nut . just slowly press the cap downwards the inside of the agitator and press it firmly then put back the softener container on top.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Kenmore 24032\24036 Top Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
46 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
