That could be many problems. what your telling me is that u see the charge light when u charge it but when you turn it on nothing happens? this could be a number of things. I would hook up a monitor and see if anything shows up on the monitor if the laptop boots. if something does show up then its your laptop display cables that are bad.
Try This
--> First turn your computer off by pressing and holding down the start button. Next unplug the computer and then remove the battery. Press and hold down the start button for about 60 seconds. Release the button and plug in the computer. Press the start button and the display should return. Replace the battery. If this does not work, try it again up to four times. No results usually indicates a bad mother board. Hope this helps.
Have
you tried a screen calibration? Turn off the unit then press and hold
the upper left of the screen as you turn it on. A dot will show up on
screen and then press the dot firmly as it moves around the screen. When
it is done it will say screen calibration complete. I also assume
you tried a reset by pressing the reset button or on the newer units
just hold the power button while turning it on for about 15 seconds
until it reboots. Thanks for using FixYa
i have the same thing happening to me. Every time im turning the sat nav drom ireland to UK it makes same beep noise and stays at ireland can you help me please
The touch screen on Garmin Nuvi 660 is not working at all. It turns on, but when I touch the screeen, nothing happens. Could it be the battery. It was low, so I charged it for 45minutes, then the gps screen dimmed and turned off after just 10-15 minutes of "messing with it"
Have you tried the reset hole? make sure there is nothing stuck in there that could be pressing on the button. When you press and hold the reset button the screen stays blank.
If you press the reset button does the unit turn on? Mine turns on when I press the reset button even after I turn the battery off then back on.
Hope this suggestion might help you restore functionality.
I had this problem. had it plugged in charging and then pressed the the reset and the power button at the same time for about 30-50 seconds and then after that pressed the power button and so far so good
