I have a Mitsubishi 55"
  • dan7bar4 Mar 22, 2011
    Alpug-- Does the power supply capacitors have to be replaced with a professional TV Repairman or is this something I can do by ordering the replacement parts? Dan
    Thank you for your help.
    President:
  • 1,961 Answers
That is a power supply issue .wavy picture is caused by a low voltage power supply.Replace the bulging capacitors at the power supply section will resolve the problem also the capacitors at the horizontal section have a close look for any bulging capacitors.good luck and let me know!
Posted on Mar 21, 2011
  • Danilo Baraquiel
    Danilo Baraquiel Mar 22, 2011
    hi sir, If you have a little knowledge in electronics repair and know how to use a soldering iron and multimeter you can do it yourself just remember to replace the exact value and rating of the capacitors you are replacing.capacitors are rated this way 100uf/50v it has a polarity on it's pin.The negative side has a minus symbol.insert the capacitors on the correct polarity pins.
    but if you do not any experience in electronics repair I would suggest to better bring it to a qualified service personnel..
Mitsubishi WS-55613 55in.
1. "wavy" may mean a signal problem inside the set--are you seeing colors out of position or skewed around letters etc?
2. Does it do it when a DVD is played? (this will rule out certain things).
SD TECH
Apr 21, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Wavy lines all over the screen on a 55 in. Mitsubishi DLP 2005 Tv that has intermitent wavy lines around all the edges of the people and edges of the screen. Jerky picture and almost makes you sic...
You probably have a V26 chassis. The only fix to this problem now that parts are no longer available from MITS is to call their Consumer relations dept. at 800-332-2119. If you have a qualified tech come out and estimate the job, Mits will offer you an attractive discount on a new model. To repair your problem would be around $750
Bill W
integrityhomeworx.com
Mar 22, 2011 | Mitsubishi Televison & Video
Basically i have an older rear projection model mitsubishi not sure of the model #, it is currently having lines run from top to bottom like waves on the picture screen! is there anything you can tell me...
Many different mitsubishi's have problems with voltage regulators going out and causing wavy diagonal lines that scroll the picture from top to bottom or vice versa. Without a model number it's difficult to clarify.
Jul 05, 2010 | Mitsubishi VS-55609 55" Rear Projection...
Mitsubishi diamond 55 Rear Projection - Won't turn on?
The DM module is not booting up because some capacitors inside it have dried up. A common problem with that generation Mitsubishi. The repair can be done in the home and most shops charge around $250 to $300 for the repair.
Jul 10, 2009 | Televison & Video
Diamond shield
It seems these TV's are going bad right and left. I would look on Craig’s list for a cheap/free 55" Diamond TV. Not sure what you would do with the left over TV. I just picked up a 55" Diamond for free and hope to fix it. If I don’t get it to work, you can have the screen (California).
Aug 03, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Screen replacement
Post a email link and I will email you the page from the service manualshowing the disassembly proceedure.
Jan 27, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
