Question about Samsung DV219AE Dryer
I have a DV219AEW/XAA dryer and it does not heat up its electric , has power but does not heat thanks john
  • Samsung Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Mar 21, 2011
I changed the belt on my samsung dv219aew/xaa dryer. Put the dryer back together tested once and worked fine. I put a load of laundry in and pressed start and then the power cut off. No lights to control...
if the belt snapped there is usually a reason
some jam up
check that and also there is a capacitor a round white tube
with two connections to it usually bolted too the motor
replace this part
you may find the heating system has a reset feature or thermal fuses
also you may need to replace the mains fuse in the plug or etc mains supply
i think as you put a load in and it cut out
then the start cap is prob short and has blown the fuse
Dec 07, 2014 | Samsung Dryers
Dryer does not dry. Wont heat up.
I am directing you to Repair Clinic.com as that will help you diagnose the issue that you are having as there isn't enough info for me to get specific info for you!
The link is; http://www.repairclinic.com/Shop-For-Parts/a8b160d1420640-x73616d73756e67206476353437316165702f786161/Samsung-Dv5471aep-Xaa-Model-DV5471AEPXAA-Samsung-Dryer-Parts
Good Luck!
Rich Lilja
Oct 06, 2014 | Samsung DV5471AEP/XAA 7.4 cu. ft. Capacity...
Samsung dryer dv219aew/xaa will not start , has
-Mostly starter is burn out . replace new one.
-Att! Disconnect power before work on!!
Good Luck
Mai
Sep 18, 2014 | Dryers
Dryer heats for maybe 1 minute then stops. Samsung Model DV328AGW/XAA
In the rear of the dryer is a thermal limiter which will kick in when the exhaust temp is too high and can cause a fire. One link will show what the limiter looks like and the other will show how to commonly get to the limiter. Your mileage may vary.
Samsung Dryer Model DV328AGW XAA Fuse Thermal Fuse Breaker Parts Take Apart Samsung Dryer Samsung Dryer Repair Help
Jul 30, 2014 | Dryers
My heating element needs to be replaced where can i get the part n what part is it my dryer model is dv219aew/xaa
If you will type "sears parts" into your computer, you will find a space for you to type in your model number.
Yours is a Samsung dryer, and there is a picture of the heating element for you.
Once you get that number off that picture, you can shop for your part at many other places, including "e-bay".
Be blessed.
Feb 07, 2013 | Whirlpool Dryers
I have a new Samsung electric dryer (DV218AEB/XAA)
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-160-1067142-/Samsung-Dryer-not-heating-DV218AEB
Click the link for no drum turning. There is a belt in the machine that wraps all the way around it, the belt has come off or broken.
Oct 08, 2017 | Samsung DV218AEW Electric Dryer
My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Jun 07, 2010 | Samsung DV218AEW Electric Dryer
Samsung DV337AEW/XAA wont turn off by timer. we
The timer has gone out rplaceit and all should be fine
Oct 27, 2009 | Samsung DV337 Electric Dryer
Samsung DV219AE Dryer Logo
1,519 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
