Question about Dell E156FP 15" LCD Monitor
Dell 15 inch lcd monitor issue
Please help.
My monitor will not come on any longer. When I press the power button, the green light comes on and message appears on the screen, "something about press 1 for digital mode". I have done everything I can think of but the monitor will not stay on. What can I do?
    Master:
  • 397 Answers
The first thing you should do is change the monitor for another known working monitor to make sure it is the monitor that is faulty and not the video output of your computer.
Posted on Aug 03, 2008
Unlock E178FP monitor menu
I don't know what you're referring to, but here is something i think it might be...
1. Power on the monitor.
2. Press and hold the MENU button for at least 15 seconds.
3. Look to see if an UNLOCK icon appears on the screen.
4. Release the MENU button and wait 5 seconds.
5. Press any button on the monitor to test.
6. Turn off the monitor if it is no longer needed.
Mar 03, 2014 | Dell E178FP 17 inch LCD Monitor
I have a Dell laptop whose screen died sometime ago. I now have a Dell E193FP monitor connected and it has worked fine until today. Now I have a black screen and an amber light. Pressing other buttons...
Sounds to me it could be a burnt or illegible ram memory card in your laptop, try taking one of them off, or switching one of them to the other slot just to troubleshoot.
Hope this helps you.
Jan 07, 2014 | Samsung SyncMaster 152N 15" LCD Monitor
I have a Dell e173pfb monitor. i push the power button and green light comes on screen comes on for a second with no problem then the backlight goes off. I can still see an image with a flashlight though....
You need a new backlight inverter board. If you dissasemble the monitor you will see a circuit board with 4 2-wire connectors connected to it. This is the board you need to replace. Typically they run from $15 to $40. Usually just easier to replace the monitor. Another idea is to reduce brightness levels on the monitor in the menu while looking at it with your flashlight. Then power off then power on the monitor and it might stay on longer.
Aug 16, 2010 | Dell E173FPf 17" TFT LCD Flat Panel...
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell monitor 15 inch the green light stays on but no picture
It's the backlight supply tripping out from backlight failure, but the thing still stays on. I got it to act right by switching to factory presets with some fast menu action once, but the general solution is going to involve tricking the backlight into staying on; you can look at the thing in bright ambient light to see that the display is still working, but of course without a backlight it's pretty much useless.
Since $100 buys a better and more efficient monitor, just replace it; otherwise of course you can either replace the backlight (or go for one of the projector mods) or convince its drive circuit to put up with it a bit longer. I spotted a bad capacitor but swapping that out hasn't gone well yet....
Mar 14, 2009 | Dell E153FP 15" LCD Monitor
Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Oct 22, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor won't display.
I would suggest that the "Event" that caused the CB to trip has caused ya Monitor to fail.. Probably in the Power Supply, My "Pet" area... lol.. anyway Thats wat I would think. It may even have an internal "Fuse" that has "Blown"?
May 03, 2007 | Dell E153FP 15" LCD Monitor
Monitor
The circuit breaker popped due to power fluctuation or something else ? It is clearly understood that your LCD monitor suffered some component burn inside otherwise it would show 'NO SIGNAL' sort of Display if it is not connected. There is nothing to resset. Please open it up & check if there is any sign of burned component or take it to a service center if it is still under warrenty.
May 03, 2007 | Dell E153FPc 15" TFT LCD Flat Panel...
Dell ultrasharp 15 inch flat panel lcd
It totally sounds like the backlight is toasted. If that is the case you will have to replace them. Normally if the power inverter is shot, the monitor will power up briefly at least and then shut off. If you can use a flash light and see some sort of image on the screen you know that your VGA chipset works however your backlight(s) are burnt out. If not, more than likely your power supply (power inverter chipset) is broken and needs to be replaced..
Mar 28, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell E156FP 15" LCD Monitor Logo
181 people viewed this question
Alun Cox
