Every thing seems to be ok . power is on plate is rotating but not warming food
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Mar 21, 2011
Center will not rotate
The glass plate is driven by a motor underneath. Power may not be getting to the motor or the motor may have failed
Jan 17, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
What do you use to keep food on a buffet warm?
: If you are using achafing dish (the metal containers buffet food is served in) the best way tokeep it warm is by using Sterno. Sternois a safe, flammable gel that burns at a very low temperature and will stay lit(and keep your food warm) for atleast two hours. It is important to remember to leave atleast2 inches between the top of the Sterno frame and your chafing dish. This will prevent the dish from gettingburned and your food from getting too hot.
May 29, 2012 | Furniture
Microwave will not heat food everything else seems to work, timer, rotating plate everything works but heating food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
=0=0=0=0=0=0=0=0=0
Sep 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I hv a 24ltr Sharp Carasoul Microwave. Few days back, its plate stopped working, but its heating the food fine. Why has the plate stopped rotating? Will the food be evenly heated even though the plate...
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You order Sharp parts Encompass here or call them toll-free at 866-779-5835.
> Will the food be evenly heated even though the plate is not rotating?
No.
Sep 07, 2010 | Sharp R-1480 Microwave Oven
Unit does not heat food. the light and rotating plate work but food is not heating.
It could be a faulty magnetron, which is responsible to warm up the food. If that is the case, then the cost price of that part is quite expensive and you are better off replacing the whole unit rather than spending money on buying the parts.Hope this helps.
Aug 14, 2010 | Samsung MT1066SS Convection/Microwave Oven
Model FMT148G1B2 - over range microwave will not heat food. Clock, lights, rotating plate in M/W all work, just will not heat/warm.
well that depends on the current. If the current is a fluctuating type then microwave wouldn't heat or else if high...please check..
Jul 23, 2010 | Frigidaire FMV156EM Microwave Oven
Why won't the food processor start
Hello :
If the cord is OK , then it seems that the motor armature is burn .
If you can fix it by yourdelf , then dissemble the unit, remove the motor. Loosen the bolts running from end to end of the motor and with emery cloth, clean the small metal plates on the ehd of the armature. They should be bright copper color. If the armature is burnt, they will be dull brown. The other thing is to replace the brushes in the motor . Or take it to a repair shop if you are not sure that you can fix it by yourself .
good luck .
please rate !
Mar 28, 2010 | Krups XL6 Power Combi Food Processor
My microwave oven is not heating the food
HI, you will need to replace the heating device. This device is called the Magnetron and, it will cost you about $133.00. This is a repairable issue but, you will need to call for service. I do not recommend installing this device if you are not familiar with handling this type of tech.
May 30, 2009 | Frigidaire FMV157GM Microwave Oven
Hotpoint Aquarius DF61 Dishwasher & Food residue remaining
i have cleaned the filter on my hotpoint aquarius DF61 on cant put it back together.
Nov 17, 2008 | Dishwashers
Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
