Question about Kenmore 54501 Dehumidifier
54501 unit is running but not dehumidifing. Unit is 6 yrs old
  • Kenmore Master
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Mar 21, 2011
Testimonial: "Thank you, I was thinking that it might be the circuit panel."
  • brad541 Mar 23, 2011
    I read your tips about dehumidifiers not working. Both of my dehumidifiers have failed due to a refrigerant leak. It appears that both were caused by corrosion on the sides of the front coil. Both units have 2 coils and the sides of the front coil are corroded in both units. Is this galvanic corrosion between the coil frame (maybe aluminum) and the copper elbows in the side of the coil?
  • D. Floyd Kolb
    D. Floyd Kolb Mar 23, 2011
    Yes, often these units do not adequately isolate the metals....they only build them to last past the warranty period...
    They really don't build them for longevity... to bad everything has become "disposable"...
Unit only runs when set to 1 cnt
unit runs If set to continuous mode only ? the other settings are a time off function that lets unit run only a portion of day , saves energy
Mar 01, 2014 | Kenmore 54501 Dehumidifier
Dehumidifer runs constantly,but captures no water in bucket
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit no
LED Screen, set the humidity extraction knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity Humid-i-stat has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 23, 2011 | Kenmore 54501 Dehumidifier
My kenmore 580.54501 dehumidifier runs and runs, but does not dehumidifer. It worked fine for 1.5 years. we looked through the troubleshooting list... alas nothing seems to work. could it be that...
ME TOO...I've bought TWO of these POS's in the last 4 years, and they both broke down in just less than TWO years...and Sears will do NOTHING for me!!!!
Nov 19, 2010 | Kenmore 54501 Dehumidifier
Kenmore Elite 70 pint unit. Compressor appears to be frozen. Fan runs and compressor attempts to engage but immediately shuts down. Any suggestions. Unit is only about 2 years old.
Hi, I think you got it figured out...
There can be many reasons why a dehumidifier willnot work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 15, 2010 | Kenmore 54501 Dehumidifier
Dehumidifer Runs but doesn't collect water
Depends on he conditions of the water. These units are relatively inexpensive and typically do not justify the expense of repair. I'ld donate it to an air conditioning school and buy another one.
Jul 18, 2010 | Whirlpool AD40USR Dehumidifier
I have a Kenmore 54501 dehumidifier
hi,
somewhere there is a "knockout" or "plug" or something similar you have to remove or replace it to get it to drain through the hose, there should be some documentation in the owners manual about it, try troubleshooting in the back of the manual. If not look directly into the hose outlet and see if theres a plastic plug there, if there is use a screwdriver or something similar to GENTLY remove the plug, you may have to just study the machine when its running to get a better idea of how the water drains, maybe the machine came with something like it in one of the plastic bags the accessories came in.
good luck
J
Jul 23, 2008 | Kenmore 54501 Dehumidifier
Kenmore 580-51650000 dehumidifier
It is more than likely the compressor is not running, only the fan.
It seams that the humidity sensor is flaky on these units. You can,
operate the unit, by opening up the dehumidifier and unplug the sensor from the main board. The unit will cycle on and off and remove the water from the air.....good luck
Apr 21, 2008 | Kenmore 54501 Dehumidifier
Dehumidifier does not collect water.
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Dec 06, 2006 | Kenmore 54501 Dehumidifier
Kenmore 54501 Dehumidifier Logo
924 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
