Question about Sewing Machines
I need a manual. The the stitch is not working
  • Sewing Machines Master
  • 1,133 Answers
Posted on Mar 29, 2011
I have a Yamata FY-900 sewing machine. It only works for the straight stitch, none of the other patterns including zigzag work. I've checked the timing that seems to be OK. Would value advice.
Watch video on YouTube for your machine. For zig zag you need to adjust stitch width. Akso where is the manual. You need a new manual to explain how to set each stitch.
Nov 14, 2017 | Yamata Sewing Machines
Can't find the stretch stitch on my singer xl100. Where is it?
Here's the manual:
Singer Quantum XL 100 Instruction Manual
I did not find a stretch stitch in the manual. FWIW, a zig-zag stitch works in place of the stretch stitch. It is also much faster and uses less thread.
Oct 13, 2017 | Singer Sewing Machines
Could not sew buttonhole . The tread gathered in one spot and wouldn't move further
Hard to assist without a make/model.
If it has a built-in buttonhole function, you may need to take it for service.
If it is a function you have to do manually, then you probably need to set the stitch length a little longer. A shorter stitch length will cause the needle to stitch on top of the previous stitch causing a big knot of thread.
May 06, 2016 | Sewing Machines
The fabric I am sewing is very soft and therefore the stitch does not hold onto the material, works fine with cotton etc. What do I need to do to so the stitch is showing. Manual didn't help. Thanks
Hmm, right off the needle comes to mind. Have you tried a new needle? Sometimes a needle dulled on woven fabric will not work well on knits. If you are stitching a knit fabric, you may want to use a ballpoint or stretch stitch needle.
Jan 23, 2016 | Sewing Machines
How do I set the stitch length and width. Have been doing as the manual said and doesn`t seem to work.
Sometimes you also need to change the foot as well for monogramming. Do check this in the manual.
Feb 21, 2015 | Brother XR9500PRW Limited Edition Project...
The auto stitch isn't working. Also, when I use the Qbot to do a linear design, the stitches are minuscule. Changing the stitch length or speed makes no difference.
The stitch length adjustment may be stuck. You need to manually loosen so the stitch adjustment can work properly. This may require you to open the top lid to locate.
Feb 02, 2015 | Sewing Machines
Can someone tell me which stitch to use on the Bernette 65 to sew elastic? I can't seem to find a stretch stitch. Thanks.
Are you sewing through elastic such as joining the two ends of a loop of elastic in a waistband?
If so, just your straight stitch or three step zig zag works fine.
If you are actually seaming on knit fabrics then you need a stitch with forwards and backwards movement to allow the fabric to give when worn without breaking the thread in the seam. tally_girl_8.jpg If this is your machine and you want to stich jersey or knits, I'd use the overcasting stitch, fifth from the right. or the tricot stitch to the right of it, this stitch is good for attaching rib trim around necks and sleeves.
Your sewing machine manual should also give you information on which stitch is used for what. I also like the Singer Sewing Manual book for good general sewing information.
Mar 09, 2011 | Sewing Machines
I need to know how to make a button hole, can't find manual.
Hi there, don't know your machine but you can do a plaiin buttonhole manually.
Set machine up for zigzag stitch, needle to left side, mark out the size you need with pins or marker pen. Start at the top and set for widest zigzag with 0 length for the top bar, cannot give sizes as don't know the button you are using, about 6 stitches, set stitch width to just over half the width of top bar and length to approx 0.5. Stitch down to bottom marker and again set up ffor the wide bar, do the same amount of stitches as the top, finish with needle down at the outside edge, turn work so that you will now stitch down the other side to meet the top bar, not forgetting to adjust stitch length and width again.
Hope this helps
Ellie
Jan 09, 2011 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
