Question about Sony KDL40U2000 40 in. HD-Ready LCD TV
My sony kdl-40u2000 lcd tv turns on then it turns off stright away and the standby light flashes 4 times goes of for a second and repeats itself ?
  • 643 Answers
Unplug for 3-4 hrs. if that doesnt help your powersupply probably bad.
Posted on Mar 21, 2011
Standby light flashes 4 times
One option to try is to try to factory reset the tv, to do this turn the tv on hold the Down Arrow on the remote and while doing this press the power button then release the down arrow button.
Bit of info on your issue
* Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Trend to find everything
Oct 04, 2014 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony KDL-46z4100 standby light blinking 12 time with few seconds gap continiously
12 blinks of standby light indicates 'Scanrate error'. You must have thorough knowledge in electronics to proceed. Actually, this is not a user repairable fault. it is very skilled work.
Jul 09, 2012 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My Sony Bravia, model KDL-46XBR4's standby light is flashing 6 times. We have reset it 3 times but after several days it shuts down and continues to flash the standby...always 6 times. Can anyone tell...
I am experiencing exactly the same problem. TV turns on but within 60 seconds the screen goes black and the red standby light blinks six times. Were you able to resolve this problem on your TV?
Oct 17, 2010 | Sony KDL-46XBR4 46 in. LCD Television
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Standby LED blinks 4 times
4 blinks on a Sony Bravia indicates a backlight/inverter (aka ballast) problem. These ballasts are regrettably only available with an entire LCD panel. :( You may perchance be able to find a parts outfitter online that scraps out TVs and have a used ballast.
Typical backlight problem on an LCD shows up as the screen lighting up for a second or two and going back off. The 4 blinks just confirms your problem.
May 14, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv immediately turns off
Four flashes indicates a problem with the backlight on the TV. It can be caused by the backlight inverter board (the power supply for the backlight) or by defective backlights in the panel It is USUALLY the backlight inverter board that is bad, but I have seen both components fail at various times. This set is fairly new and should still be withing the one year warranty, so you should contact Sony at 800-222-SONY to get it repaired. Be sure to rate this solution. Thanks!
Nov 16, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony KDL40U2000 40 in. HD-Ready LCD TV Logo
829 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
