Question about Roland Hp337 Digital Piano
I have a key which had dropped and no longer works. Can I fix this? I'm fairly good with tools.
  • Roland Master
  • 5,603 Answers
This service manual will be close enough to your unit:
http://elektrotanya.com/roland_hp-335.pdf/download.html
Scroll down near bottom to where it says "Get Manual" and click on that.
They will let you only download two a day without being registered.
Posted on Mar 21, 2011
How to repair a casiotone MT-520
Did all those keys fail at once? If so, it's likely a simple fix, eg a single broken wire. Keys are usually wired on a grid array eg 25 columns x 3 rows.Pressing a key eg connects the 17th column to the 2nd row so the device knows which key it was. So if there is a broken wire to one of the rows, 1/3 of the keys will suddenly stop working.
Oct 31, 2017 | The Music
How can I fix a broken key? A cat drop something onto my keyboard and a key popped off. It just floats there and I can't get it back in place.
There are 3 different types of key fixing, can you let me know the model number and I will be able to offer you some ideas.
Sep 20, 2015 | Yamaha Portable Keyboard
Roland EP50 F sharp does'nt work.All other keys are fine
EP-50's are notorious for problems with either the 4.65 voltage feed to the velocity sensitive keys or failure of the small zenner diaodes. Each key has a pair fo split circles on the circuit board under it. When you hit the key you connect each side of the circles and the harder you hit the keys the quicker the circuits close the louder the sound. Problem is if the voltage to either circle fails, due to bad solder, scratch on circuit board, failed diaode then the sound disappears. The fix is simple if you are knowledgeable on solder on circuit boards, can use a multimeter and can dissassemble and reassemble the keyboard. If you have to take it to a repair shop it is probably not worth fixing as this is not one of the better Roland products
Dec 03, 2012 | Roland Music
Korg m50 freezes after 10minutes
Hello I have this M50 61 key korg model, I had the same issue the fix is simple remove the back cover on the unit, carefully push in all the small cables reattach them well do it to all the small connectors these cables get lose and cause this issue, good luck let me know if that helped I fixed mines that way its been working excellent since. good luck..
Jun 08, 2012 | Korg M50 61-Key Music Workstation Keyboard...
THere are a number of keys that are stiff or "stick" and do not play properly. IS ther a simple fix?
Check if front of key is hitting the case. If it is, analyze why it is happening. If unit has been dropped this can happen. One can sometimes move the whole key assembly back slightly if this is the problem.
Jan 03, 2011 | Williams Allegro 88-Key Digital Piano
My Roland Juno d has contact issues. I need to have the contacts cleaned once a year because I keep losing sound on some keys and some sound too softly. I am tired of shelling out $135 every year for a...
Answer:
Before i give you the right solution, i have to say that i have posted the answer to FIX the problem of all of the contact problems, people writing in how many of their keys are not working. And the post that they are showing is one that says to clean the contacts. That will not work.
Ok,
the answer.....
You can purchase a kit called Rubber contact kit here: http://www.mcmelectronics.com/product/20-3890&cid=prodCrossSell
or
Key contact Kit:
http://www.oaktreeent.com/Roland_Keyboard_Parts_Units.htm
These kit are made to re-coat the contacts on the keys. It will bring your board back to brand new condition and last as long if not longer than the original coating.
Also can be used for any rubber contacts like remotes or game controllers. etc.
This will work and i did mine after numerous times of taking the keys off and cleaning them.
I hope this gets out to all of you that are having the same problem.
Good luck
Jun 21, 2010 | Roland Juno-D
DJ LIGHTS
MOST DJ lights are not protected to be used outside in weather.
Other considerations are visibility from highways and also aircraft. Certain lights could cause a problem for these two scenarios.
When outside, often the distances are longer and the light drops off as the square of the distance.
Laser types require fog to get the effect and there really isn't a way short of getting the weather to cooperate and give you fog to get those effects.
Between the laws of physics and the construction of lighting intended for interior use, what you are asking for is just not easily obtained.
The inability to control ambient lighting outside is a real problem. Many of the DJ things require a fairly darkened room. The sky glow from a city is enough to kill off the effects.
May 19, 2010 | American DJ Flash Beam Lighting Effect
I have a CDP-100 and need disassembly instructions for access to internal keyboard assembly. Unit was dropped while unloading from car. Now some keys are akimbo and won't play as though they are off their...
I just fixed my CDP 100 which had a similar problem - dropped and two keys not working up one end.
1. Lay keyboard upside down on soft surface. Under keyboard is plastic cover held on by 17 screws. Remove all these and lift cover away. The metal key ends are all revealed.
2. Locate the disloged keys. Carefully press them back into position - they will "click" into place. Make sure the corresponding key on the keyboard isn't stuck in an "up" position - you may have to remove the metal key part and replace it again while making sure the key is correctly seated.
3. Replace cover and screws.
Feb 22, 2010 | Casio Music
My roland Midi keybaord (pc 200 mkII) has keys that don't make contact...there are these rubber pads for each key with little metal contact on them ...they don't appear damaged, assuming that is the...
Over time and with hard playing the pads can develop rips in them and will no longer make contact. They used to come in sets and were fairly easy to replace. The second thing if they aren't damaged is to clean them by rubbing gently with a pencil eraser and removing the residue with rubbing alcohol. The same can be done on the circuit board where the pads make contact. Make sure everything is perfectly clean before reassembly. Hope this helps.
Jul 11, 2009 | Music
How to remove keys for complete cleaning
I've worked on a lot of keyboards and they're all different.
Unless you have the service manual, a good set of electronic tools and have the time, don't attempt it, take it to a keyboard services specialist. If they know what they're doing, you'll get you keyboard back in good working condition.
Apr 30, 2009 | Music
Roland Hp337 Digital Piano Logo
148 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
