System is taking long time to boot so,i restarted by pressing the power button .then,after that it is restarting again and again.
  • 76 Answers
Do you get a blue screen just before the laptop restarts? If so you should try booting up into the recovery partition and repairing Windows, if that doesn't work you should look at replacing the RAM or HDD.
If you cannot access the recovery partition or you do not know how post back with the make and model of the laptop and I will talk you through the process.
Posted on Mar 21, 2011
    Genius:
  • 1,542 Answers
Hi
not knowing what make and model laptop you have you could try this
turn offf laptop
restart laptop pressing the F8 key a few times until it takes you into the repair options
then you could try some of the options
i would try this one first of all
last known good configuration
click on it and windows will restart and try to take it back to when it worked ok
failing that
you could try the restore option and restore back to when it was all working good
good luck
The problem of my hp pavilion dv5 is this, i want my laptop to be back on its original state so i tried system restore. i have my recovery discs aside from the built-in recovery partition. i inserted the...
You have formatted the hard drive (containing Boot Manager) using recovery disk 1.
That's why the error message.
Just insert disk 1 again.
Shut down the computer (press & hold the power button for a minute).
Restart.
Follow the instructions that come up.
If it doesn't help, reseat the hard drive. (open the back cover, take out hard drive, reconnect it)
Also you may go to BIOS (tap F1 while booting) and set the cd-drive as the first boot device.
Hope it helps.
Nov 06, 2010 | HP Pavilion dv5-1000us Notebook PC
Tip
To Reboot or recovery from CD/DVD problem with OS "Aser"
If you don't press the Alt+F10 key combination or use the recovery CDs, can you get into Windows? Boot with the recovery CDs in. When at the Acer logo during POST, press the F12 key. Then, select boot off CD or DVD. Alternatively, you can enter the BIOS by pressing the F2 key at the Acer logo and go to the Boot tab. There, you can set the CD/DVD drive as the first item in the boot order.
When turning your laptop on, before Windows starts booting, a splash screen appears first (usually with the logo of the manufacturer). Look on the splash screen (usually at the bottom) for a key (usually F10 or F11), assigned for System Recovery. Some manufacturer(s) (e.g. HP) place the recovery files to a hidden (mostly) partition of the hard drive, the others give a Recovery CD/DVD with the laptop.
or
  1. Press the start button from the start menu depending on your operating system(win 2000,xp)
  2. Press Ctrl+Alt+delete combination from the keyboard.
  3. If you have a power button on your laptop keyboard,it could also be useful by pressing and hold it down for few seconds
N.B: "Ctrl+Alt+Delete" can exit you from usage and trigger a reboot
or Shutdown. Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up. Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot.
Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately. Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually.A few seconds should do unless you have additional problems.
All the Best!
on Sep 13, 2010 | Computers & Internet
How do I reboot my acer laptop with my copy disk?
When turning your laptop on, before Windows starts booting, a splash screen appears first (usually with the logo of the manufacturer). Look on the splash screen (usually at the bottom) for a key (usually F10 or F11), assigned for System Recovery CD/DVD with the laptop. or 1.Press the start button from the start menu depending on your operating system(win 2000,xp) 2.Press Ctrl+Alt+delete combination from the keyboard. 3.If you have a power button on your laptop keyboard,it could also be useful by pressing and hold it down for few seconds N.B: "Ctrl+Alt+Delete" can exit you from usage and trigger a reboot or shutdown. Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up. Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot. Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately. Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually. A few seconds should do unless you have additional problems.
All the Best!
Sep 12, 2010 | Computers & Internet
When i press power button cpu fan and power led start, but not able to get screen and boot programe , i keep it on for long time , restarted may times .but i dont work
Power down your computer and disconnect everything from it, including all of your cards and usb connections. Take out your battery and then put it back in. try the power button again and see if the laptop will start.
Sep 11, 2010 | Computers & Internet
My HTC Diamond restart and restart and restart....
It might be something you have installed. I think the fastest way to get rid of such a situation is to perform a hard reset. You must know that you'll loose all your personal data, and how to do a hard reset, but here I go, anyway. There two ways to hard reset your Diamond.
Software way: Go to 'Start > Settings > System tab > Memory > Clear Storage tab', enter password '1234' and tap OK.
Hardware way: Turn your device off. Then, press and hold the ENTER key. Whilst keeping this key pressed, briefly press the POWER button. Release the ENTER key when a waring screen comes up. Then, press the VOLUME UP button to hard reset your device, or any other key to cancel the hard reset procedure.
Hope you are able to sort your problems out.
Cheers! Carlos
Apr 12, 2010 | HTC Touch Diamond Smartphone
Hey man im trying to reboot mny dell d505 and i inserted the disk and everything but it says exit the disk and restart again even when i take the disk out it says exit the disk and restart the laptop wtf??...
press all the buttons keep restarting keep pressing all buttons till somet happnes also u could try taking battery off if its a laptop also taking memory out for the night and maybe hirens boot cd .
OR BRING up boot menu boot cd 1st 2nd had and whatever else good luck he he
Jan 26, 2010 | Dell Latitude D505 Notebook
My lenovo laptop after resuming says it is hybernating and continues to shoe the same for hours together .it hags on. it is not starting again pl let me know how to start. i am new to laptops. ihave been...
Install the operating system again. I think your operating system is corrupted. Or it has shut down improperly while installing updates.
So you have to install os again.
cheers
Jul 10, 2009 | CMB T43 750 Notebook
Can't recognize wireless adaptor
RESTART YOUR COMPUTER, ON REBOOT, CLICK F10 WHEN YOUR CHANGE BOOT OPTIONS SCREEN COMES UP. YOU MUST PRESS F10 QUICKLY OR IT WILL LOAD WINDOWS AND YOU WILL HAVE TO RESTART AGAIN. ONCE YOU GET INTO THE BIOS SETUP UTILITY GO TO SYSTEM CONFIGURATION, SCROLL DOWN TO BOOT OPTIONS CLICK ENTER. GO DOWN TO INTERNAL NETWORK ADAPTER BOOT AND ENABLE IT. THEN GO TO SAVE AND EXIT. AFTER YOU RESTART YOUR COMPUTER, CHECK IF THE WIRELESS IS WORKING. IF LATER IT FAILS AGAIN, GO BACK INTO THE BIOS SETUP, IF THE ADAPTER IS STILL ENABLED, DO A DIAGNOSTIC TEST FROM THE BIOS UTILITY. IT WILL DO A QUICK TEST (IT IS FAST) THEN IT WILL DO A COMPREHENSIVE TEST, THIS WILL TAKE AWHILE UNTIL IT FINDS THE PROBLEM. BE PATIENT IT WILL FIX IT!!! THE COMPUTER SHOULD AUTOMATICALLY SHUTDOWN WHEN IT FINISHES. WHEN YOU TRY TO TURN YOUR COMPUTER BACK ON, IT MAY NOT COME ON THE 1ST TIME, THIS IS OK TOO. JUST KEEP PRESSING AND HOLDING THE POWER BUTTON UNTIL IT COMES ON AND STAYS ON. NOW WHEN YOUR COMPUTER LOADS WINDOWS YOU WILL SEE YOUR WIRELESS ADAPTER IS WORKING.
Jul 01, 2009 | Computers & Internet
System not booting
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
aamknr-23
Feb 03, 2009 | Mercury P4VM800M7 Motherboard
Thinkcentre M55 8806 power on off problem
May be your computer motherboard wires connection get loose or getting moisture in wires. Or there may be some earthing problem in ur power switch. First, check the wires connection & tighten up properly. if problem persists, check the earthing by power tester. Check you RAM if it is properly tight in the jack.
Dec 26, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
