Question about Cyberhome CH-DVD 300 DVD Player
Dvd player does not power on unit is pluged in
  • 325 Answers
This is an internal repair. There are two in-line capacitors nearest the power input. They will be very small capacitors (likely 470uF 10v). You must match the uF value and INCREASE the voltage value to make your dvd player live again.
Thank you!
Posted on Mar 21, 2011
20 inch LCD TV/DVD PLAYER COMBO MODEL#. CFTD2011 When pluged in tv will not turn on with remote or power button
either a power supply failure of some kind or the set is in shutdown because of a short somewhere inside---old or new unit?
Apr 23, 2012 | Akai Televison & Video
ITS PLUGED INTO AN AC WALL UNIT. TURN IT ON AND AN EMPTY BATTERY FLASHES WITH THE WORD CLOSE AND IT GOES OFF. WHY IS IT SHOWING AN EMPTY BATTERY WHEN IT'S USING AC?
hi,
if u are using an adapter( power supply) then it have some problem. just replace the power supply the problem will solve. now the the dvd is attempting to work on battery because it did't get power from its AC power supply.
ok
Dec 30, 2010 | Insignia NS-PDVD8 Portable DVD Player
There is no picture from the rear vierw camera
You need to check the power for your camera.The positive at the reverse light works well. Yo0u also need to go in the menu and make sure the avic unit is programed for the camera. And check to make sure you are pluged into the proper port.
Sep 05, 2010 | Pioneer AVIC-D2 DVD Nav/6.5"...
Sees the ipod but not the songs. All it says is connecting...
Hi and thank you for using fixya:
Please to a cold reset on your unit by un-pluging your power cord from the back of the unit. Also check that cable does not has any damage.
thanks
Aug 03, 2010 | Valor ITS-702W Car DVD Player
DVD PLAYER DIED ALL OF A SUDDEN. NO LIGHTS,NO POWER, NO SOUND. NOTHING. UNIT IS PLUGED IN AND WORKED FINE YESTERDAY.
Your probably got a blown fuse, You might want to unplug it pop off the cover and check the fuse. if its blown carefully take it out and bring it down to radio shack for a replacment.
hope that helps you out please to forget to rate.
Apr 05, 2010 | GoVideo D2730 DVD Player
Unit will not come on.
check the voltage of power supply,and the voltage to board, if has no reading in board maybe the regulator on power supply is not working
May 05, 2009 | RCA DRC8320 DVD Recorder/VCR
Phillip DVD Hard drive power failure
You should take firt a voltimeter and test for 5 and 12 volts at power input to de HD,(pluged to the wall) as some times is the power with has been fried...if so test diodes first and transformers then (unpluged from the wall...) if not ok and you do not know how to fix the power source take it to an electronic shop and they will perform a standard repair as it is only a power source......
Feb 11, 2009 | Philips DVDR520H DVD Player/HDD
HELP WITH A PORTABLE DVD PLAYER PLEASE!!!
Question: You can't see it (movies) without it being pluged in!, Can you see it when it is pluged (A/C, or DC power) IN?
Do you have FRESH batteries ? The "JACK" for power inside the player could be damaged.
Lets the power from the plug in but does not connect for power from the battery.
2nd) When you buy a new equipment you usually get a manual with at least 2 languages. I'll TRY to download it in ENGLISH and you translate it.
send me the model # of the "Polaroid" dvd player
Jul 24, 2008 | Televison & Video
Will not play any DVD
Turn off and disconnect power from unit. Check laser shuttle worm gear, look for dirt or hair (as I found). Remove with tweezers carefully. Check lubrication of worm gear shaft. If gone or worn, use white lithium grease to lube (very little). Play music CD 2 - 3 x. Than DVD. Worked for me.
Jun 01, 2008 | Mintek DVD-1710 Portable DVD Player
Red lıght on the front panel
No problem about pluging 110v ac if your dvd is auto volt from 100-230volt. when you plug your dvd press power button in your unit or in remote. if dosent any fucntion need a repairman tech.
Apr 01, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
