Question about Kitchen Ranges
I have a 5500 series Maytag front load washer I get an NF code No Full. washer works fine on cold/cold cycle. when on cold/warm I get NF. checked hoses no clogs.
  • RIchard Campolei Mar 21, 2011
    yes very I was aware of the valve. Thank You I will look at it or replace it if it can not be cleaned.
  • 17,970 Answers
NF code is a "No Fill" fault: this indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill.
You need to, first, make sure the water supply is turned on; second, if the water is turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. Also could try in this link the Consumer Display Table Code
The Maytag Neptune models (
front load Maytag washing machine) was made by Samsung, them its possible that this documents helpfull:
- Owners Manual -->> applianceblog.com/manuals/16026736.pdf
- Service Manual -->> applianceblog.com/manuals/16025909.pdf
Hope this helps you.
Posted on Mar 21, 2011
HOT and COLD not blending correctly
The explanation I have in my file is that powder detergent does not dissolve properly in cool and warm wash cycles unless there is some hot water flow. However, I agree with your assessment.
Nov 09, 2013 | Maytag Legacy Series Top Load Washer
Mah 6700 is stopping after 1 minute with a reading of NF
Did you check the screens in the watervalve when you removed the supply hoses? They can crud up over time and restrict the flow. Clean them in-place with a toothbrush and spray bottle. Reconnect hoses and test. While testing move temp switch from HOT to COLD to WARM settings and observe flow of water and temp of water in each position. Cold may flow a little faster than HOT but should be close to same flow rate. WARM however should have twice the flow rate of hot and cold temps seperately. Let me know what you find.
Jan 21, 2013 | Maytag Neptune Washing Machines
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune will not spins and gives the code nf. I have been told that there is a reset code. Does anyone know the code?
Hi
Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water.
Try running the diagnostic test by—
  • Press the delicates and heavy soil keys together for 3 seconds.
  • You are in the service mode.
  • Now, press wrinkle free key, cold water should start entering.
  • Then, press the cotton sturdy and hot water should flow.
  • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer stops during the wash cycle and nf appears on the display screen
NF code is Washer does not turn on water valves to fill washer with water. You may need to replace your water valves, but I would first try removing your hot and cold water hoses to see if the screen on your valves is clogged. If they are corroded beyond repair, just pick up another set at the hardware store. Either that or you will need to do the valve replacement.
Mar 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune TL
The machine needs to cut you a break;
“”i have a maytag neptune TL and there are several things wrong with it...1. I can't wash small loads it will stop at the spin cycle and flash dc””
This issue is a clutch issue see this post to DIY the repair.
“”it will wash fine on regular loads until it comes to spin cycle again and it will stop and flash nf””
This one is a little confusing the “nf” error is a No water fill error code. Check these two post for support regarding water inlet restriction or valve not opening properly.
nf post nf post 2
“”my fabric softener dispenser will not let the softener out neither will the bleach dispenser””
See this fabric softer post for support. The fabric softener dispenser may be clogged or the water dispenser valves feeding both dispensers may not be operating properly. The Service Manual on page 16 “Board Output Test” will give you support to turn on the Fabric Softener Valve and Bleach valve. See if you hear the valves operate in Service Mode”
My method may seem a little confusion for viewing water flow to the dispensers. This issue could be associated to the nf error you are receiving, restricted water flow (inlet screen clog) or cold water valve not working properly.
Post back for any questions or possible support I can offer. I’m an owner like you not a repair person but I’m very comfortable working on this machine. Rich
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Cold water valve won't turn on to fill washer
either the valve has failed or the water line screen is blocked.
Aug 31, 2017 | Maytag Neptune MAH5500B Front Load Washer
Kitchen Ranges Logo
139 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
