Question about Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool gold quiet partner III. The cancel drain button works but nothing else. If you press any of the button for a period of time the normal button flashes; nothing happens though. Any thoughts????
  • Whirlpool Master
  • 3,247 Answers
Try to reset the dishwasher by using this sequence of keys within 6-8 secs.
HiTemp/ heat Dry/ Hi Temp/ heat Dry/ Hi Temp / Heat dry.
If it works all lights should turn on. Press Cancel to exit.
I am assuming you have already tried to turn the mains power off and back on.
If still no difference, then the controller or the panel has packed up.
You can locate the parts from this site.
Posted on Mar 21, 2011
  • mollymea Apr 13, 2011
    this helped right away...thanks!
  • madisondaly Jun 08, 2011
    I've had a similar problem on two occasions now, however mine would be so frozen that even the cancel button wouldn't work. The first time it was the clean light flashing, and last night it was the normal light flashing. I had remembered that the first time, I was able to get it out of its funk by trying different reset codes posted on this website. I did all of them and did not have immediate results as most people have posted, that all the buttons would turn green and it would reset. Actually, none of mine turned green, with the exception of the continually flashing clean light. Well, I walked away having given up, and when I came back 30 minutes later, it had gotten out of the frozen funk it was in, and was back to being normal. Wierd. Maybe one of the codes actually worked, but took a while to reset. Anyway, last night, this was not the case. I tried every code I could find online, and even did them in sequences numbering up to 80 times pressed... and still nothing. Well, my friend was over and sees me frustrated with this piece of junk machine, and says "whats this button?" and she holds down the accusense button, and all the lights went out. I was in shock! So just to be sure, I pressed Cancel and it went into the 2 minute cancel/drain cycle. We both were thrilled! Yay!
    So... long story short... try holding down the Accusense button?? Worked for me apparently.
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
I recently replaced the chopper in my whirlpool quiet partner III. now it won't drain. I can push the cancel drain button and hear the pump running, but nothing happens. I tried reversing the wires to...
It sounds like you've done a lot to try and fix your dishwasher. Make sure your air gap is not plugged up and double check the drain hose. If those are clear change out your drain hose. Part#8270145 the elbow connector sometimes have a bad check valve and could keep it from draining.
Hope that helps Thanks please rate me
Dec 11, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner III Will not drain at the
It sounds like the control unit has gone bad and you will have to replace it...the replacement is not very hard, just make sure to mark the wires so you get them back were they belong on the new unit.
How to Buy Appliance Parts Online
heatman101
Sep 18, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Dishwasher slowly fills with water
Greg, at this link you can download available manuals for your unit.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=GU1100&siteCd=WHRCOM
Good luck with your repair.
Please take the time to rate this solution.
Jan 29, 2009 | Dishwashers
Whirlpool Gold Quiet Wash Plus GU940SCGZ3
Press the cancel button, Then cut power to the dishwasher for a period of time. restore power to it then try a cycle.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold- quiet partner III
An angel of mercy on another blog posted this solution and it worked for me as well. My Whirlpool Quiet Partner Dishwasher would not work due to the CLEAN light flashing in 7 interval sequences. I followed these steps and my dishwasher is not working perfectly...hope it works for you:
"Well for mine which is a Whirlpool Gold Model # GU2400XTPS3, I found the seq of buttons that I had to push to reset the curcuit board. I think it may of been in this forum somewhere. But I had to push - Sani Rinse, Heated Dry, Sani Rinse, Heated Dry, and then the dishwasher went through it's diagnostic cycle and then after that the light stopped blinking and the dishwasher works great. Supposily, there is a Product Tech Sheet behide the kick panel of every dishwasher, but mine was gone so I had to find the information on the internet. You might want to do a serach for the correct seq of buttons you have to push to reset the curcuit board. If you know for sure that the heating element is bad, you will have to order one. "
Mar 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,214 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
