Question about Minolta Di152 Laser Printer
Hi, Could you walk me through How to overwrite all data function on the Konica Minolta DI251 digital copier? Thank you. Micheline
  • Minolta Master
  • 6,696 Answers
Does it have a hard drive.? because it will not have anything in it. remove the rear panels to check
Posted on Feb 22, 2015
SOURCE: Connecting my Di251 to the finisher
Make sure the actuator pin is still attached to the mid left section of the copier. It's a metal pin about 3 inches long (we call it the "shwartz", ha,ha) that is inserted into the finisher when the finisher is pushed close to the copier.  It is normally mounted with 1 or 2 screws.
Posted on Oct 21, 2007
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
Nitrotrike
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Posted on Feb 10, 2008
  • 60 Answers
SOURCE: Konica Minolta C450 User Manual
http://kmbs.konicaminolta.us/content/products/models/bizhubC450.html?info=Manuals
Posted on May 27, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
My konica minolta di2510 is showing co500. i figured out it is from the power board and i have checked fuses and they are ok. so what could be the problem of the power board
did u checked with other Fusing Unit on same machine with same power supply board. c500 due to Fuser heating error.
are u able to reset first?
Dec 03, 2016 | Konica Minolta Di2510 Di251 Di250 Di2010...
STARTS TO PRINT,THEN STOPS AND CODE C1300 POPS UP.
print head is bad replace it if you can find one that is a legacy Minolta machine, Now Konica Minolta, try this site for a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 13, 2014 | Konica Minolta Di200 Di200f Di250 Di250f...
Windows 7 driver v2045
Try this web site but the Di251 maxed out at Windows 95 best might be XP Self Help Product Support Konica Minolta Business Solutions Inc
Jul 02, 2013 | Minolta Di251 All-In-One Printer
Code 00500 Di251 what to do?
we are deals in repairing/ amc/ rental of all types of konica minolta
or canon photocopier in delhi & ncr
Gaurav Pahuja 9811139117 , 9990258388
Aug 03, 2011 | Minolta Di3510f Bizhub Copier
Failed to overwrite all data bizhub 250
the overwrite data function is supposed to take about 35 hours but the ones that i have done took about 20 hours and ounce the process is started you should never interupt it this function overwrites all the data on the hard drive HD-504 you could try formatting the hard drive first then overwrite again
1touch the utility/counter button then details
2 press stop,0,0,stop,01
3 enter 00000000 touch end
4 touch tech rep mode
5 touch function
6 touch hard disk format
7 touch yes
8 touch enter when the message the hard disk format completed.result:ng appears touch ok
9 touch hard disk format
10 touch yes
11 touch enter this starts the formatting procedure
12 when the message "the hard disk format completed. result:OK appears touch OK
13 press the reset key
14 touch exit on the tech rep screen
if the format fails replace the hard drive the format process takes about 30 minutes if you need further instructions on how to replace the hard drive post it
Dec 04, 2009 | Konica Minolta Office Equipment & Supplies
Minolta Di251 Paper Feeder doesn't work. Need estimate to repair
Common problem with these models.....most likely if it sounds like it "tries" to feed you original then the feed rollers need to be cleaned. On the front left corner of the document feeder cover there is a single screw. Remove the screw, open the F1 door and the cover will come off. Now right where the originals feed in you will see 4 feed rollers or small "tires" The 2 smaller ones or the usually the main cause. Just take a cloth with some glass cleaner on it and rotate and cleaned both sets of tires. Reinstall the cover and you should be good to go.
Oct 14, 2009 | Konica Minolta DiALTA Di200 Copier
Copier won't print - IP address was switched?
i need a service manual of minolta di251 digital cpier
Dec 11, 2007 | Konica Minolta DiALTA Di200 Copier
Minolta Di152 Laser Printer Logo
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
