Question about Video Game Consoles & Games
Basically,i put in the usb of the xbox controller and it only shows 2 lights on the controller,no flashing jus on.its the 1st light on da left nd 2nd light on da right.help plz
  • 32 Answers
Your xbox lights will light up and stay lit for each controller connected to your xbox.
If you have two lights on, that means two controllers are connected. (possibly your wired controller and a wireless controller) if you were to disconnect one of them, one light would go off.
Posted on Mar 22, 2011
My xbox 360 is now showing flashing 1 red light on and off
These steps are taken from the support site as always, it's the first website where you should look.
Solution 1: Disconnect and reconnect cables
Here's how:
  1. Turn off your Xbox 360 console.
  2. Unplug all memory units, controllers, and accessories from your console.
  3. Unplug everything from the back of your console, including power and video cables.
    Don't remove the hard drive.
  1. Reconnect your console's power supply.
  2. Reconnect each accessory one at a time, starting with a controller.
  3. After you've reconnected every accessory, turn the console on.
Solution 2: Remove the hard drive
To see whether the problem involves the original Xbox 360 Hard Drive, temporarily remove the hard disk drive. Here's how.
Note Not all Xbox 360 consoles include a hard drive. If your Xbox 360 console doesn't have a hard drive, to go Solution 3.
  1. Turn off the console.
  2. Locate the hard drive on the top of the console (or on the left side, depending on how the console is oriented).
  • Press the release button on the hard drive.
  • Lift the hard drive away from the console.
hdseparating.jpg If these steps resolve the issue, reattach the hard drive to verify that the error occurs only when your Xbox 360 Hard Drive is connected.
Solution 3: Disconnect memory units or USB flash drives
Here's how:
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on the console.
If these steps resolve the problem, reattach the memory unit or USB flash drive to make sure the error occurs only when it's connected. If this is true, order a replacement memory unit or use another USB flash drive.
Solution 4: Request a repair
If the previous steps don't resolve the single flashing red light issue, there are no additional troubleshooting steps. Your original Xbox 360 console must be repaired at our service center. Start the repair process online.
Jan 09, 2015 | Microsoft Xbox 360 Console
Nyko charger won't charge
Had same problem with blinking lights and not charging.
Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
Feb 07, 2012 | Nyko Charge Station 360 For Xbox 360
I have recently bought a mazda 929 luce limited nd its got a v6 engine 3.0l 18 valve ,,its been parked for over nd year ndd upon changing da transmission fluids today i have been successful in moving...
Hello and welcome to FixYa!
One thing that can cause this is a faulty torque converter. If the torque converter is faulty, the shifting of the vehicle fails. One good reason why it only shifts on 2 gears. Have it replaced and you'll be good.
Hope this helps and thank you for using FixYa! Have a good one!
May 04, 2011 | Mazda 929 Cars & Trucks
I have got one power cable going to a 2 gang switch and need to feed two seperate lights off it.
Hello.
All whites are marretted together,
  • white power - white 1st light - white 2nd light
Blacks are the return for each light, and are joined after passing through the switches,
  • black FROM 1st light - top of switch - bottom of same switch - black power AND other black from 2nd light (see next step)
  • (repeat of above) black From 2nd light - top of 2nd switch - bottom of 2nd switch - black power AND black from 1st light
NOTE: both switch blacks are marretted together to the black of power. Ground all 3 as normal to dblgang box. Total marrettes required is two (three if using one for grounds) Hope this helps. If so, please rate a four-thumbs up, Thank You.
Apr 02, 2011 | Home
There is a light on the dashboard that I do not
I believe it's the washer fluid light
Here's a list of your dash lights and their meanings
Left
1. Door-ajar warning light
2. Oil pressure warning light
3. Check engine warning light
4. Tour or Sport for the ECS
5. Security indicator
Center Warning Lights
1st space down
Left: 4-wheel steering oil level warning light
Right: Brake warning light
2nd space down:
Left: Anti-lock brake warning light
Right: Active Exhaust Tour indicator
3rd space down
Left: cruise control indicator
Right: cruise control ON indicator
4th space down:
Left: charging system warning light
Right: High-beam indicator
Right Warning Lights
1st down: Not used
2nd down: Seatbelt warning light
3rd down: Washer fluid (2 storage containers)
4th down: Supplemental restraint system (SRS) warning light
Oct 07, 2009 | 1994 Dodge Stealth
2 left lights flashing.... still
Buying cooler attachment is not going to help - it doesn't indicate that it's overheating but it indicates that the Xbox has a proble of 2nd level. To fix it, you have to send it back to Microsoft if you have a varranty, if not you have to buy a new chip replacement set which is aviable on the internet.
Feb 11, 2009 | Microsoft Xbox 360 Console
Wireless controller
you have to link controller to xbox under disk tray to right theys a small round button press this green rings flash, whilstflashing press xbox button on controller so it also flashes this will link them
Jan 03, 2009 | Microsoft Wireless Controller for Xbox 360...
My screen is black
the screen on my sidekick 2008 is cracked need to find a screen for so i can get it to work
Dec 10, 2008 | T-Mobile Sidekick
Xboxe 360 console arcade
you got the red lights of doom #1 suggestion make sure your harddrive is plugged in all the way #2 make sure all cables are pluuged in if thats not it go onto the web fin da video of how to get three red light instead of one nd send it into microsoft becuase your warranty cover three lights not 1 or 2
Jan 02, 2008 | Microsoft Xbox 360 Console
HELP
will be a hardware error
will have to contact microsoft there is a temperory fix for this problem. what you need is two towels just normal bathroom towels take everything out of your xbox e.g
harddrive,controlers etc only things to leave in is the av cable and power supply as you wanna turn
on the xbox lie a towel flat on the ground and lie the xbox on its side ontop of the towel turn the
xbox on, you will see the error message and the red lights flash. wrap the towel around your xbox
covering the air vents and then the 2nd towel put over the top. leave it on in the towels for about
20 mins then after that take all the towels off turn off the console and leave to cool down for 15
mins. turn the xbox on and it should restart again fine but only lasts for a couple of days then you
have to do it again. wont fix it but will let u play while microsoft gets it.
hope this helps please rate me
regards Grant
Nov 22, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
37 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
