Question about Microsoft Windows XP 2005 (M9300091L)
Screen frozen when I use mouse cursor dousnt move no commands from keyboard work either.
  • Microsoft Master
  • 1,381 Answers
Hello ,budderfly131
Replace batteries in both mouse and keyboard . Press connect button at the rear of each one .
Verify receivers connection to the pc and make sure the receiver is placed in a reachable sector for the mouse .
Best regards ,
fanaudi .
Posted on Mar 21, 2011
    Problem Solver:
  • 5 Answers
If it's an old PC, chaces are, some parts stop working. The power supply could be malfunctioning, or the HDD (hard disk) could be too old. If the HDD stops, the whole pc freezez, and won't come back.
I recommend trying cheap second hand parts. Have a semi-expert install them. if you are familiar with computers, you can do it yourself. Just power off things and plug the same plugs to the same places. Mind jumper setting.
    Master:
  • 325 Answers
Press and hold your power button till it shuts down.
this is a common crash, youll get one every now and again, not to worry unless it happens daily.
Mouse/cursor works fine on PC but disappears when watching recorded TV using windows media center. model KB3800TPW
Usually when watching something on your computer in full screen the cursor will disappear. If it comes back when you move the mouse then you have nothing to worry about.
May 03, 2011 | Gear Head WIRELESS keyboard/Mouse
I have a Toshiba LapTop Windows 7 My granddaughter pushed keys and now i can't get the cursor to move. I have tried shutting down and it is still frozen in the middle .
Are you using the trackpad to manipulate the cursor, or are you using an external mouse?
If you're using the trackpad, it may be as simple as using the Fn keys and the corresponding F keys at the top of the keyboard to enable the trackpad feature again. If that doesn't work, try plugging in an external mouse via USB port to see if that works.
If you're using an external mouse, then try to see if the cursor moves while using the trackpad.
Hopefully one of these options will give you control back over your cursor again.
May 03, 2011 | Toshiba Satellite Pro L300 Notebook
Frozen keyboard & mouse on Acer Notebook
You may have a motherboard failure problem. I would ask you to check the drivers and update them but will be hard to do if you can't get past load screen. You best bet may to get a copy of system recovery and boot pc with the disk installed. Wipe computer completely clean and reinstall windows.
Aug 18, 2009 | Gateway (4000274) Motherboard
Dell wireless mouse cursor froze in middle of screen.
Hi, my cursor had frozen on my screen after my grand daughter pressing something. After trying everything I decided to take it to a local computer shop, it was fixed in seconds. He held the arrow tab(below the caps lock tab) and then pressed F9 it worked!!
Hope this will fix your problem
Jul 27, 2009 | Logitech 3-Button Cordless Optical Scroll...
Left click won't work.
Sounds like the shift or command or control buttons are stuck on your keyboard.
Mar 17, 2009 | Apple MacBook Mac Notebook
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
Mouse doesn't alays work.
check the hard drive for any problems and re-install the drivers for the mouse
Nov 16, 2008 | HP Computers & Internet
Mouse Cursor Frozen
If your plugging it into a P2P (which are the green and purple circular ports that your and keyboard go into) for mouse to get power, it would require a restart. I suggest using a USB mouse because it a plug n go.
Oct 23, 2008 | E-Machines eMachines Desktop PC
Microsoft Wireless Optical Comfort Desktop and Mouse combo Freezing Prob.'s
have you tried pressing the connect button on the reciever then on the mouse so it picks it back up again?
May 01, 2008 | Microsoft Multimedia Optical...
T20 cursor frozen
Computer mouse help and information A mouse is a hardware device which allows the user to control a cursor to manipulate data .... CH000981, The wheel on my mouse is not working properly.
How to navigate Windows using a keyboard. Not only does this help users who do not have access to a mouse, it can also save you a great deal of time when working with text documents.
E-mail CHID: 6268 This feature enables you to move a mouse cursor or use mous buttons using ... also possible that your keyboard could be bad, causing the keys not to work.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | IBM ThinkPad T20 Notebook
Microsoft Windows XP 2005 (M9300091L) Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
