Question about The Adventure Company Tortuga Two Treasures & Sealed PC Games for Windows
Hi i have tryed to install the tortuga two treasure pc version but it says copy protection driver not installed execute file DrvSetup.exe on cd/dvd drive. what shall i do to get the game working? i have windows 7.
    Sergeant:
    Champion:
  • 218 Answers
Locate DrvSetup.exe on the cd/dvd drive and run it. you will need to have the cd/dvd for the game in the drive than right click on the drive click explore than a list of files on the cd/dvd will appear find the one that is DrvSetup.exe and double click it
Posted on Mar 21, 2011
I have a new pixma mp258 printer but i can't install it using a cd cause my cd drive is busted, so i need another way to install it
try to insert your CD in another PC and open it from my computer by clicking start/my computer/right click CD/DVD drive/click open or explore/copy the files inside of the CD installer including the setup.exe and the driver into USB flash drive.then insert your flash drive on your PC.open it double click the setup.exe or the driver folder.inside the driver folder should have an exe to install the software.
Sep 23, 2011 | Computers & Internet
How to fix and repair a not valid win32 application?
Often this error message will be similar to the below error message.
C:\Program Files\myprogram\program.exe is not a valid Win32 application.
Cause
This issue can be caused by any of the below possibilities.
File is corrupt, bad, or missing.
File is not designed for your version of Windows.
File is a virus, worm, or other malware file.
Hardware incompatibility.
Answer
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install or after the program has been installed because it was not copied properly onto the computer.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
If the program is an older MS-DOS program or early Windows program you may get this error.
If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Getting old MS-DOS games to run in Windows.
This error can be generated by a file that is a virus, worm, Trojan, or other malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus or infected.
If the file has been checked and is clean, it is still possible that the virus protection program or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue.
If you're getting this error during the installation of a program it's also possible that the CD-ROM drive or the drive you're installing the program from is not compatible with Windows or has drivers that are not compatible with Windows.
Download the latest drivers for your CD drive or other drive through our drivers page.
Source : ( http://www.computerhope.com/issues/ch000726.htm)
May 30, 2011 | Microsoft Computers & Internet
Not a valid Win32 application
Answer:File is corrupt, bad, or missing
Download files
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Bad file
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
If you're attempting to run an older computer game in a new version of Windows, see document CH000587 for additional suggestions about getting older games to work in Windows.
This error can be generated by a file that is a virus, worm, trojan, or other type of malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus and/or infected.
If the file has been checked and is clean, it is still possible that the virus protection program and/or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue. Additional information about Safe Mode can be found on document CHSAFE.
May 30, 2010 | Rosetta Stone Spanish (Latin American) -...
I want to install sound driver so which should be first step
put your driver cd in your cd/dvd . Usual it will autorun . If not (and if you have autorun.ini) view the inside of the autorun.ini and you'll see an instr. executable . copy /paste that instruction (usually the path to a exe file) or double click on that exe.Press auto install of the audio driver .
The "expert" way :
you are in device manager -> audio device (will have a yellow "?"),open,update driver , browse to the inf file (always for older versions of windows).
Mar 14, 2010 | Microsoft Windows XP Professional
I own a Lexmark X1270. I just recently changed computers. I went to install my printer only to realize I had lost the installation disc. Can I replace this?Is there a download available online?
You can download the installation drivers from here and follow these instructions (choose which operating system you have)
To install the Lexmark X1270 All-in-One Printer driver, download the version of the driver that corresponds to your operating system by clicking on the appropriate link. A window should then show up asking you where you would like to save the file. Save the driver file somewhere on your computer where you will be easily able to find it, such as your desktop. Then follow the instructions below corresponding to the file type that you downloaded
exe (Executable File) Go to the location where you saved the file and double click on the file. Then simply follow the on-screen instructions for installing the driver
If you need to update the Lexmark drivers afterwards you can do so from are here
If you still have access to your old computer you can make a back up of the installation files. To do so, find your lexmark folder in your operating drive and copy the complete folder to a CD/DVD. Place into your new computer and double click on the installation executable file.
Hope that helps.
Jan 18, 2010 | Lexmark X1270 All-In-One InkJet Printer
Installing Vista on new hard drive- CD/DVD Driver not found
Are you installing from the SONY-supplied "System Restore" CD/DVD disks, or from a "generic" Vista DVD-ROM?
The SONY disks _should_ have the correct drivers for your notebook computer.
Dec 08, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
Cannot run application (*.exe)
what is the application?
It sounds like you are trying to run a Win 16 (Windows 3.x) program
Jul 26, 2009 | Dell Inspiron 1420 Notebook
Computer wont read the software!!!
i think yur cd has been corrupted.. please take a fresh copy of a installation file and install it.
Jul 06, 2009 | Microsoft LifeCam VX-3000 Web Camera
Error Message 'F:\ setup.exe is not a valid win32 application'
  1. File is corrupt, bad, or missing.
  2. File is not designed for your version of Windows.
  3. File is a virus, worm, or other malware file.
  4. Hardware incompatibility.
Answer: File is corrupt, bad, or missing
Download files
Bad file
Mar 18, 2009 | Computers & Internet
The Adventure Company Tortuga Two Treasures & Sealed PC Games for Windows Logo
765 people viewed this question
Top The Adventure Company Video Game Consoles & Games Experts
john h
Andrew Taylor
Andrew Taylor
Are you a The Adventure Company Video Game Console and Game Expert? Answer questions, earn points and help others
