Question about Cdt Audio HD-53ST Car Component System
I have brought these speakers, when i turn the headunit up above about 3 quaters of the way they distort, they are running off a 4 channel 4ohm amp with 400watt rms but they do it with the gain on the amp turned right down. i have put the amp to high pass crossovers are installed that came with speakers. the headunit settings are all set to flat no bass etc. they sound bad when the bass kicks in. any ideas. thanks
    New Friend:
  • 25 Answers
Make sure your ohm load is at rated for the item that is powering them. they may work better at 4 or 8 ohms if you run them together. also turn the bass down on your cd player or head unit
Posted on Apr 28, 2015
  • 5,603 Answers
If you run the power amp at a very low setting it makes the amp subject to noise and distortion. You want around a 60% setting.
Speakers also need to have proper loading, that is in a cabinet or enclosure that is kind of matched to them. If the amp is rated at a true 400 Watts RMS then the speakers should be at least 800 Watts as they "cheat" on those SPEAKER ratings and MANY A SPEAKER IS BLOWN AS A RESULT.
Posted on Mar 21, 2011
How to wire a crossfire vr602 2 channel amp at 4ohm and 2ohm
I would be more worried about the amp than the speakers, those subs should handle the watts with no problem. The problem will be in the amps ability to remain working with a bridged 2 ohm load. It may not even stay on without going into protect mode with a 2 ohm load. If it does stay on then it may get really hot and shut off from the heat off of the Mosfett Transistors, or it could burn the Mosfetts from driving them too hard. Basically it's your choice, run your amp hard and gain more volume or run it with slightly less sound and have a cleaner sounding more stable amp that will stay on and have less chance of being damaged. If it's not loud enough the best thing to do is buy a different amp that better suits your needs and fits the application. In your case a 2 ohm stable Mono amp is going to be your best bet or a 4 channel amp bridged into 2 channels and run with 4 ohms on each channel. Or another exact matching amp like your 2 channel amp bridge them both and have each powering 1 of your 4 ohm subs. I used two VR mono amps to power my two 12" 4 ohm subs for a few years
Apr 03, 2013 | Crossfire VR602 Car Audio Amplifier
What is the actual watts per channel @ 8-ohms and 4-ohms on the Behringer PMP3000?
Those specs would be right - I have this same board but the amp was fried by a previous owner. I pulled the amp board out and tossed it and use the mixer now to drive an external amp. Great board. This amp is rated at 1200W "peak", bridged into an 8ohm load. That would equate to about 900W RMS bridged into 8ohm or 450 per side into 4ohm loads per side. You can't daisy chain all 4 speakers....impedance would be too low. You can run two of your 8ohm speakers per side - that results in a 4ohm load per side for the amp. That would give you amp delivery of 450W per side. Your speakers are rated to handle more than that so you're fine. For the record.....you could run one speaker per side no problem....just lower power output.
Aug 16, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
I have a 50x2 amp that is bridged 100 into a 4 ohm load. can i run this to a 6x9 3way speaker rated 100rms 4 ohm
Yes, you can. There's the impedance match between amp and speaker (4ohm to 4ohm).
The only issue I would say is that if the amp is putting out 100 watts RMS, then you wouldn't want to drive the speaker to the max, because it's rated at 100 watts RMS max, and at louder volume, it will start to distort and possibly blow from fatigue. Other than that issue, it should work fine.
Jul 22, 2009 | Car Audio & Video
What is the best way to connect 4 speakers and a sub to a 4 channel amp.
I would connect the 4 speakers to channels 1-2 in stereo with high pass filter. Bridge the sub to channels 3-4.
A thumbs up would be greatly appreciated if this answer is helpful to you. best-way-connect-4-speakers-sub-4-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
May 01, 2009 | Car Audio & Video
Speaker Distortion
I would definitely say yes to the new HU, however at the same, the issue could be the actual wiring from the deck to the speakers. If you've got a cassette player in there I'm assuming the vehicle is a bit older. Over time the copper in the wiring has a tendency to corrode if exposed to the weather. Either way replacing the player is a win-win situation since you'd be stepping into the CD era (lol), but if it doesn't make a difference I would be looking towards the wiring. Outside of that the only possible wild card would be you bought faulty speakers, the odds of that being very low since it's coming from both. Hope this helps.
Nov 18, 2008 | Rockford Fosgate Punch P163C 3-Way Speaker...
Help on 1 amp and 1 alpine srw-124d
You have dual 4-ohm coils. 2 coils per speaker.using one speaker, if you take and run the postive from one coil and connect it to the negative of the other coil, then take a wire from your bridge channel on your amp and connect the positive to the the remaining positive on the one coil and connect the negative to the remaining negative on the other coil you will create a 8ohm load on the amp in bridged mode.
now this is the important part. The bigger the load on the amp the greater the wattage output to the speakers. This sucks the wattage out of the amp. Careful not to overload you amp. The setup above is safe for any amp. The following is for 2ohm stable amps only. The lower the ohm value 2, 4, 8 and so on, the greater the load on the amp.
connect the positive of one coil to the positive of the other. connect the negative of one coil to the other negative of the other coil. then take a wire from your bridge channel on your amp and connect the positive to the the positive on one coil and connect the negative to the negative on the same coil and you will create a 2ohm load on the amp in bridged mode.
Series = add the two ohm value
parallel= halve the ohm value
you can play with series and parallel together using more than one speaker setup.
Jun 07, 2008 | Alpine Type-R SWR-1242D Car Subwoofer
Sony xplod 500w 4/3 channel
If the speaker is a 4 ohm DVC (two 4 ohm coils), you can't wire it to get a single 4 ohm load. Try connecting one coil to each of the two rear channels. It may not be as loud but the amp should operate without going into protection.
If the two 4 ohm coils are in parallel, the amp is driving a 2 ohm mono load. That's probably why it's shutting down.
Apr 25, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Can I Add two 12" subs and 2 pairs of 6"x9" speakers to my amplifier
you could try to wire the subs in a series which all positives are connected in a line from amp to pos of sub to pos of other sub , same for the neg.
heres sum extra reading materials:
http://www.crutchfield.com/ISEO-rgbtcspd/learningcenter/car/subwoofers_wiring.html
Nov 10, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Behringer ep2500 amplifier
Yes you can,,,,,BUT the output labelling on the AMP will tell you where you can connect the 4ohms or the 8ohms....please read these labels and connect the 4ohm speakers to the 4ohm terminals, and the 8ohms to the 8ohms terminals...
If you intend to connect the 4ohm and the 8ohm speakers in parallel then the output impedance terminals you use should be the 4ohm ones.
If there is no labelling showing any 4ohm output terminals then its best if you dont use the 4ohm speakers at all....just connect the 8ohm to the 8ohm terminals...you dont mention any crossover networks inside the speaker boxes or if you have tweeter speakers... so just stick to the basics above at present....
Cheers From YUBEUT
Oct 20, 2007 | Sunfire Cinema Grand Signature 400 seven...
Cdt Audio HD-53ST Car Component System Logo
197 people viewed this question
Top Cdt Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Cdt Audio Car Audio and Video Expert? Answer questions, earn points and help others
