APC back ups ES 500odes stop charging the battery.
  • 1,915 Answers
The battery is probably dead if the unit is over three years old.
Posted on Mar 21, 2011
Blinking red and green lights
Check battery and charging voltages. APC says 90% of faults are a dead battery. My experience also
Oct 15, 2014 | APC Products - APC - Back-UPS ES 750...
How can you tell if the system is bad on apc back ups es 650
plug something (other then a computer)into it, turn the gadget on, then unplug the UPS. If the gadget continues active the UPS is OK. Generally after you have punched every button (circuit breakers). After that put a Volt/Ohm meter on the batteries (and the charging wires to check the charging curcuit is OK.
Apr 29, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
My apc back ups es 650 has a continous chirp what doe that mean?
the chirp means a power event has occurred and the unit needs reset to continue operation , power events can be a few things ( to large a current was applied as a load to it , the power stayed off till battery failed and it had to charge it back up when power comes back on )
Apr 29, 2014 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
APC BACK-UPS ES 500VA fails to provide back up during power failure
Get APC Powerchute Personal Edition for free and run it. If it says your battery isnt charged, check its voltage disconnected. Charge it with a car battery charger and see if its still a good battery. If not , replace it. If the battery is good, then check the charging voltage. Should be about 14 volts. if not, check the small transformer on the main board. Should be 120 in and 17 to 18 out. 4 diodes in a bridge for charge. The input to the transf has small fuse into it alone.
Jan 04, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
My Apc Back UPS Es 500 did not charge and then there is power when I turn on the switch. How could I repair this problem?
Good Day! Try changing the battery. please visit apc's service center for battery replacement. it will only take 3-5 working days. once done, your ups will be as good as new.
Nov 09, 2010 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
Need charging instructions for apc back-ups es 350
Take off the bottom cover and make sure the battery is connected (both terminals).
Plug the unit into a wall outlet.
Press the power button to turn it on. Leave it plugged in for 8 hours to charge the battery. Do this with nothing plugged into the unit.
Done.
Aug 08, 2009 | APC Back-UPS ES 350 UPS System
APC ES350 strange noise
My solution was to unplug everything, hit the reset button, and then power the unit back up. The problem I found to be that I had my laser printer connected to the "surge + battery" side, and for some reason no laser printer can be connected to it.
Sep 28, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
23 people viewed this question
k24674
jasbo
jasbo
