Question about Frigidaire Dishwashers
Water not draining in dish washer. - Frigidaire Dishwashers
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Posted on Mar 21, 2011
SOURCE: Water not draining
were is the drain plug located and how do we remove? help
Posted on Sep 27, 2008
  • 7 Answers
SOURCE: Neff intergrated dish washer
Drain pump is either faulty or blocked, follow drain hose back to d/washer pump is at the end, always isolate from power supply before attempting any work
Posted on Oct 09, 2008
wheelshot
  • 102 Answers
SOURCE: dish washer not draining
May be that there was a little regular soap or something put in that made it suds up. vegetable oil poured into the dish washer tub will remove the suds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem.
Posted on Apr 11, 2009
  • 74 Answers
SOURCE: du401 doesn't drain water
there is a little pump at the bottom of the machine,called the askoll pump".this is what pumps out water before and after a cycle.the pump needs replacing.
Posted on Nov 02, 2009
Testimonial: "Thank you for your post. This is out of my area of expertise and I'll have to call the repairman on this."
heatman101
  • 43501 Answers
SOURCE: dish washer is retaining water in the bottom of
Check out this tip that I wrote... it will give you some things to check and see what is happening...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
Heatman101
Posted on Feb 26, 2010
My lg dish washer leaves the dishes dirty and the soap is still in washer
check water hook up and its hooked up to hot water line or washer is not draining if water still there spray arms may be plugged up
need more info model # help
Dec 04, 2016 | LG Dishwashers
Whirpool dish washer has water coming out the air gap when flushing out of dish washer
I think you have a clogged line. the drain from the dishwasher goes up to the air gap and also into your sink drain pipe.
hope this helps
Jul 05, 2012 | Whirlpool Dishwashers
The dish washer will not drain. There is water in
there is probably astuck peice of glas in the propeller. manually drain unit. take a torc screwdriver and remove screw in bottom of unit. you are removing a piece that looks like a plastic cover. now carefully spin the propeller and take out what is stuck ,put back screw then hit cancell and drain. that should do it. let me know if this was helpful
Feb 23, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Does not pump water. Leaves dishes soappy
We really need your model number to help you properly. In the mean time you can check you sink connection and air gap for obstructions. Usually the cover just pulls up and off then you unscrew the cap to expose the drain tube for the dishwasher. More often than not if the unit fills and washes but leave soap on the dishes a clogged drain line is the problem. You may have to run something down the drain tube to clear it. Usually you will see the obstruction when you remove the cap. There is a remote possibility if it drains into a garbage disposal that food particles have clogged the drain outlet inside the garbage disposal. Hope this resolves your problems. Cheers!
Sep 20, 2009 | GE 15" Laundry Pedestal for Horizontal...
Water backs up to the dish washer from the sink .
Check the drain hose under the sink. It should have a high loop an upside down "u" like a hill the water can't climb to get from the sink to the dishwasher. That is where I'd start. Good luck.
Jan 07, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Mucky water after cycle complete
poss a blocked drain or a backe feed from the sink remuve drain hose and check.
Nov 13, 2008 | Dishwashers
Jul 24, 2008 | Neff 24 in. S5456 Built-in Dishwasher
No Drainage Stoppage?
The drain hose has to be higher than the full water tub level or it will keep draining out make sure your hose is high enough
Feb 06, 2008 | Haier HLP21E Top Load Washer
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Dishwashers Logo
35 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
