I have tried everything i possibly can today - I've bought a reconditioned laptop. its an IBM Thinkpad T43. I couldnt connect to my wireless at home, long story short, sky broadband told me its because i'm running intel wireless and I need to change it somehow by updating my driver or modifying it so it will talk to my router properly but he couldnt assist me any further due to not having intel. Today i've updated my driver and its still not working. I called IBM and they remotely took over my computer, and as much as the girl sounded and looked like she knew what she was doing, it didnt get me anywhere. Only thing she pointed out which might have made sense is that the sky bloke knew nothing and was talking ****. Since that conversation I've still been trying to get online at work on the wireless and its still having none of it. I've tried turning everything on and off ect. (radio) and still nothing.
  • Derek Blackburn Mar 21, 2011
    What version of windows is this? Also are you using the windows wireless configuration or a different utility. If you are using the windows utility are you seeing any wireless networks?
  • 3,287 Answers
The wireless should only care about 5 things. When the radio is set to "on", these 5 things are:
1) Wireless B, G or N. B is 11mb, G is 54mb and N is faster still - on the order of 100mb and more. N is backward compatible with both G & B speeds and G is backward compatible with G and B speeds and B will only connect at B speeds. You should be able to connect, but only that the speed will only be as fast as the type (B,G or N) supported by both the router and the notebook. Some routers (LinkSys) offer a "G" only speed - this means a B speed device will NOT connect. Make sure your notebook will be able to connect before setting the router to an exclusive speed limitation.
2) SSID. The SSID in the router MUST match exactly that which is programmed in the notebook. You can simply set the router to "broadcast" the SSID if you think you may have entered in incorrectly in the notebook. This way, the notebook will detect the SSID and offer to connect to it whenever you are close.
3) Security encryption type. You can choose None, WEP 64 bit, WEP 128 bit, WPA or WPA2 (there may be others, too). The list is presented in order of least security or desirability to the most robust or difficult to access. You should select the most robust security encryption that is available on BOTH the router and notebook. If you select WPA2 on the router and WEP128 on the notebook, they will not connect.
4) Security keys must match. Once you have settled on a common security encryption type, you need to have the same keys. Just as there are millions of Yale locks, not all Yale keys will open all Yale locks. Choose a number, phrase or use the utility software to set up the key. You can ofter use a hex-decimal number 0-9 and A-F. A good starting point for a security key might be your cellphone number.
5) Stay in range of your wireless router. Routers will be accessible from anywhere from 25 feet to 1/4 of a mile! This is a very wide range of distances that are the result of antenna types (two directional antennas pointed at each other can achieve 1/4 mile distances or more) while at the short range a metal wall or concrete wall between a router and notebook with poor antennas may have trouble connecting at just 25 feet.
Lastly, if you have left the router unsecured (highly NOT recommended) and you have left the router username and password at the factory default, nearly anyone can change the settings in 1, 2, 3 & 4 above and lock you out of your wireless. You should change these settings to something unique and change the username and password of the router as well. Write the username and password down on a piece of tape and stick to the underside of the router for later if needed.
I hope this helps and good luck! Please rate my reply - thank you.
Posted on Mar 21, 2011
I have an older ibm thinkpad laptop, Tried to add memory, a new fan The power and fan and hard drive started , then powers down
Hi There,
Make sure all of your connections are tight, and that the RAM, HD connector, and anything else you've touched is seated correctly.
If you tried to put more RAM in than the computer will allow, it will not turn on. If you've unclipped a wire somewhere or your RAM isn't seated correctly, it will malfunction.
Check and then double check everything.
Jul 16, 2012 | IBM Thinkpad T43/p Notebook
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
Dec 04, 2009 | IBM ThinkPad A21m 2628 Notebook
I reloaded xp on IBM t43 but wireless lan is not working. i downloaded driver but still no good
Is the wireless turned on?
Make sure the antenna wires are connected to the WiFi card.
Nov 16, 2009 | IBM ThinkPad T43 Notebook
IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
    It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
    Note: Follow the instructions provided to enable wireless card.
    • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
    • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Oct 07, 2009 | IBM ThinkPad R30 2656 Notebook
Adding wireless printer to thinkpad T43
If you have a wireless router, the printer will talk to the router and not to the thinkpad. You would have to establish a connection between the printer and the router. Then share the printer to print.
If you dont have a wireles router and you are trying to connect your thinkpad to the printer directly, the wireless card in the thinkpad should be in the adhoc mode. ( See Wireless card properties )
Hope this helps
Thanks
Ranjit www.supportminds.com
PS: Dont forget to rate me if you got your answer.
Aug 13, 2009 | IBM ThinkPad T43 Notebook
Wireless adapter not visible
Is it not physically connected or is there an on off slider switch thats turned off ?
Still does not explain why its not showing up in device manager.
Apr 15, 2009 | IBM ThinkPad T43 Notebook
Can't set up wireless connection
On IBM laptops, you have to hold "FN" key and push the function key that has the wieless icon on it.
Sep 27, 2008 | IBM ThinkPad T43 Notebook
Gateway 6846 wireless not working
fn-f7 fixed the screen rotation problem on the ibm t43
Sep 09, 2008 | IBM ThinkPad T43 Notebook
Wireless / cable connection
By cable connection, do you mean a LAN cable or a phone cable or something else? Let me know and will see what I can do to help.
R-
Nov 07, 2007 | IBM ThinkPad T43 Notebook
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
