Question about Zhumell Meade ETX-70AT Astro Telescope 0705-04-10 with 494 Autostar Computer & Meade Tripod FREE UPS
The vertical lock knob on my Meade ETX-70AT was over tightened and is broken. I contacted Meade and was told that they no longer stock this part. Looking for a source for the part.
  • 3,186 Answers
You might be able to drill a hole through the plastic knob and use a washer and a bolt to hold the screw tight. Or do something like this fix:
http://www.schlatter.org/Dad/Astronomy/etx90decknb.htm
Posted on Mar 21, 2011
Anyone know where to find a replacement VERTICAL LOCK KNOB for a Meade ETX-70? Or what fix might work instead?
Look at the link below for a FIX for a broken Dec knob. This is a common problem so once it is fixed do NOT overtighten.
See this:
Aug 06, 2015 | Meade ETX-70 (240 x 70mm) Telescope
I have a Meade ETX-90/ec telescope, the verticle lock knob will not thighten. It appears to be stripped. how can I fix it? Where can I get a parts list? Thank you
The bolt is stripped away from the plastic knob-- TAKE THE vertical lock knob off and inspect the bolt head-- you can use a STRONG glue to fix it -- epoxy or something similar.
Aug 29, 2011 | Meade ETX-90EC (325 x 90mm) Telescope
Adjustment lever part is for the ETX 60AT tripod leg. Two of three are okay but the third is broken. Never been out of the box.
Contact Meade directly for any replacement parts. You might also find something at a well stocked hardware store that will also work.
http://www.meade.com/support/index.html
Aug 30, 2010 | Meade ETX-60 AT Telescope
First time using the mead etx 60at. I turned it on and set the date / time / enter. Then set it at north and horizontal,enter. It asked if i wanted the easy alignment, I said yes. I said searching. Then it...
Did you lock down BOTH clutches?
You should have Calibrated motors and trained drives before you actually tried to do a goto.
Read this manual completely:
http://www.meade.com/manuals/TelescopeManuals/ETXtelescopes/ETX-60-70AT%20manual.pdf
Aug 21, 2010 | Meade ETX-70 (240 x 70mm) Telescope
My Meade ETX-125EC Telescope has a broken horizontal lock lever where can I get a replacement? thanks
Meade can probably sell you one :
You might also find something that would work to tighten it at a well stocked hardware store.
Apr 18, 2010 | Meade ETX-125EC (500 x 127mm) Telescope
Vertical adjustment/lock knob is broken-any ideas how
You can do a do it yourself repair.
http://www.weasner.com/etx/techtips.html
and or call Meade and see if you can order a new part.
Oct 13, 2009 | Meade ETX-80AT (240 x 80mm) Telescope
I have a Meade ETX-90EC. I cannot tighten the vertical lock to engage the motor. Motor works fine (I think, I can hear it turning) but the knobbed dial just keeps turning (clockwise) and never seems to...
It's a simple solution!
Take the knob off, and use a simple washer, will will hold up in between the plastic and metal surfaces.
This should be your solution!
Aug 07, 2009 | Optics
Zhumell Meade ETX-70AT Astro Telescope 0705-04-10 with 494 Autostar Computer & Meade Tripod FREE UPS Logo
759 people viewed this question
Top Zhumell Optics Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
Are you a Zhumell Optic Expert? Answer questions, earn points and help others
