Question about Leviton Illuminated Decora-Style White Wall Switch
I installed a Decora white illuminated wall switch to control a fluorescent bathroom fixture; the switch is advertised as working with fluorescent fixtures but does not. When I turn the light off the switch illuminates for a second or two and goes out. i've tried new switches - same problem. Does this have something to do with the fluorescent fixture? It is an older type - not CFL. Thanks
  • 75 Answers
Sounds like a problem with the fixture, not the switch. I'd say replace the ballast, or just replace the whole fixture.
Posted on May 08, 2011
Fixture not working after bulb change
"CFLs" Compact Fluorescent Bulbs (with built in ballast) must be labeled as dimmable to be used on a dimmer circuit.
Traditional fluorescent fixtures must have a dimmable ballast installed inside and can be used with standard fluorescent lamps.
Fluorescent lamps must be sized to match the ballast. CFL's are matched at the factory, but others are not. Older fluorescent lamp fixtures have a ballast inside. A type rating is to operate (2) 48 inch / 40 watt lamps. Newer fluorescent lamps are rated for 32 watts, and these will not work - or will have a greatly reduced life.
If you installed CFL's, the first thing I would do is install regular incandescent lamps and see if it works as expected. If not, something else is wrong - otherwise - make sure you've got the right lamps in the fixture.
Mar 17, 2014 | Electrical Supplies
Why does motion sensor not fully illuminate a fluorescent 4' light?
many motion sensor do not work with fluro tubes as stated on the fitting instructions as it has the same affect as you turning the switch on and and on to change from auto to manual operation
the problem comes from the ballast and the starter operation
Jul 04, 2017 | Heath Zenith Occupancy Motion Sensor Wall...
Single Pole Illuminated switch doesn't interrupt power to fixture.
there should be two wires coming from switch both black you should hook up the hot wire to one the other to the light it self. if there hooked up right then the switch would be bad if you have a volt tester this will tell if you have a hot wire or not , good luck
Sep 08, 2011 | Leviton Illuminated Decora-Style White...
I have three wires, two are black and one is white. I want to have the outlet active and the switch control an overhead light. How do I connect the wires?
Connect the white on the switch to the white in your house, one black to the hot coming in, and the other black to the hot wire to the overhead fixture.
Mar 13, 2011 | Leviton Decora Combination Switch - 5625-I...
Have 3- 13 watt mini spiral bulbs on fixture. When switch in auto mode, lights hum, flicker and not maximum brightness. When switched to on position, lights stop flickering and humming. Full brightness as...
-Replace the compact florescent bulbs with regular incandescent bulbs and see if problem continues.
-Lighting controls are made for different kinds of bulbs.
-Your package should say what the watt rating and type of bulb.
According to the PR180 manual:
-I am looking at the Leviton PR180 occupancy sensor manual, and the PR180 sell-sheet, and these documents say for incandescent and fluorescent (rapid-start magnetic ballast only).
-Compact fluorescent are supposed to have a magnetic ballast.
-The manual does not specifically say it works with 'compact fluorescent'
-The manual does not say there is a minimum amount of wattage either. Some controls will not work correctly if the overall wattage is low. Your overall wattage is 39watts.
Read the product package (if this is a new installation and you have the package)
Try the incandescent bulbs.
If the PR180 is not your product, add a comment with product number and I'll look for information
Nov 06, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
I am installing a Leviton Photoelectric switch and have two wines in the box Black which has power when tested and White that shows no power. The switch has three wires Black, Yellow and Red. What is the...
Something doesn't sound right here. The 5611 series products list themselves as being single-pole products with screw terminals - and you're describing what sounds like a three-way device with wire leads. It almost sounds like the wrong product was put in the box. Regardless...
First of all, I want to make sure that we're replacing a light switch. I am assuming that the two wires are the hot feed, and the switched-hot return to the light fixture. I dont' want to rule out the posssibliity that if, say, a receptacle used to occupy this box, the white white may actually be a neutral - in which case, installing a switch here will cause a short.
Assuming for the time being that it is a standard 3-way switch, of the three wires on the unit, one should be listed as the "common", and the other two as "travellers" - connect the common to one of the two house wires coming from the wall, connect one of the travellers to the other house wire, and place a wire nut on the remaining traveller (unused). If you can't figure out which wire is which, just guess and if it doesn't work, try a different wire combimation - there's only three possible ways to wire it and only one of them won't work.
Oct 17, 2010 | Leviton 104-05611-2WS 15A Decora Single...
Triple rocker switch to control 3 function bathroom fan/light
I suggest you cut 3 pigtails out of your black wire (about 5-6" each and strip them so you can put a nut to tie them all together on the main wire, then do the same for your grounds using green 5-6" strips of wire and then connect all 3 switches with the pigtails to their proper locations. This WILL fix your problem.
Mar 08, 2010 | Leviton 1755 Triple Rocker Switch Decora
I'm installing a vanity light in the bathroom. The old one had a dimmer attached. For the new fixture, attached two white from the wall to the white in the fixture. attached two white from the wall to...
Get a test light, a bulb in a socket with a black and a white wire. disconnect both the black and the red. Also have access to the white or the ground. Then with the power hold the white test light wire to the white of the house and the black to the black. .turn the dimmer on and off and see if it controls the light. NEXT do the same with the red, that is test light black held to red and test light white held to house white. once again check the dimmer.
Typically when you have a hot red and a hot black in a fixture the black is on the dimmer and the red is always on because it is connected to an outlet built into the light. OR the light can be controlled from two locations, one regular switch and one dimmer switch.
Mar 01, 2010 | Electrical Supplies
I have an outside spot light with a motion detector controlled by an inside switch. I want to change outside fixture & install dimmer switch in place of wall switch. I removed outside fixture. There...
First, let me say that if you're not entirely comfortable doing high voltage electrical work, you might want to call an electrician. It's not impossible for you to get hurt or killed or burn down your house. At least be sure to turn of the circuit breaker while you're working on it.
The blacks and whites twisted together are passing through power to other parts of your premises and are always on, so be sure to keep them twisted together. The red is the one that will take power from your light switch and send it to your light fixture.
At the fixture, connect the white to white and red to black, the same as before. At the light switch, connect the black to one side of the switch and the red to the other. When you turn on the switch, it will permit power from the black to travel down the red to the fixture, and from the fixture, the circuit will be completed through the white.
Sep 12, 2009 | Leviton (102-5G108-RW5)
Wiring a leviton 5625-W switch receptacle combination
You cannot replace the switch with a switch/receptacle combo because there is no neutral wire. The black and white that you see are both used as hot wires. One is the Line and the other is the Load.
You have to install another 2 wire cable or replace the existing with a 3-wire cable. A 3-wire cable has a black, red, and white, plus the bare ground wire
Sep 02, 2009 | Leviton Decora Combination Switch - 5625-I...
Leviton Illuminated Decora-Style White Wall Switch Logo
156 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
