Question about Amana Refrigerators
Amana Model ARB2217CC Refrigerator not getting cold enough. Someone told me to clean coils. Where are they located
  • 1314 Answers
SOURCE: Fridge does not get cold enough
first the freezer does all the cooling there are air vents in top of the refrigerator that the evaporator fan draws air through then blows it down to cool the fridge in the fridge section you should see an air vent if you don't have a defrost problem then you have an air flow problem first do you hear the fan running if you see heavy frost on the back wall of the freezer wall where the fan is then you have a defrost problem and that's a different repair but if you don't then remove the four screws and pull the panel carefully as the fan is there see if there is heavy frost on the evaporator a large aluminum honey comb so much that air cannot come through it under that part will be an a tray with around hole in it make sure that's is not frozen and the drain hole is open then check that the square hole that goes down to the fridge is clear and check the two square styrofoam intake blocks are clea you an pull them out gently and see if its iced up under there after you check that reply to me on any fault
Posted on Dec 31, 2007
22yooper
  • 828 Answers
SOURCE: Side by side Sub Zero not cold enough.
How old is "OLDER" ? If there is no frost buildup on the back wall of the freezer you could have one of two problems. On older units the compressor wears out with years of service and no longer pumps efficiently. Or it could possibly be low on refrigerant charge. ether one of these two problems is a sign that is time to update to new unit.
If you have frost buildup on the back wall of the freezer section you then would have a problem in the defrost circuit attributed to the timer, defrost heaters or defrost thermostat.
Posted on Jun 11, 2008
Krazytech
  • 725 Answers
SOURCE: amana side by side does not freeze nor does it get cold
first check you freezer back for frost if a lot of frost defrost the whole freezer ,,, then plug back in and see if it will work..
let me know
Posted on Jul 08, 2008
  • 15 Answers
SOURCE: freezer is building up frost and refrigerator is not cold enoough
Almost certainly, you have a leak within the freezer compartment.
The cooling system will use a divertor valve to concentrate coolant to the fridge or freezer compartment - whichever is necessary to maintain selected temperatures.
If a seal within either compartment is compromised and leaks then the coolant will be excessively diverted to that area in an attempt to lower it's temperature - the other section will suffer since more coolant is diverted to the weaker area; the weaker area that is being excessively cooled will also have more moist air circulating, hence moisture will contribute to a build up of ice - exacerbating the problem.
Ensure that both fridge and freezer doors are closing properly, if they appear to be secure then also check that the seals are airtight - there should be no ice accumulating around them.
You might need to re-align the doors, or less likely, replace the door seals.
Please reply if you require further clarification or help.
Posted on Jun 01, 2009
kvhappliance
  • 218 Answers
SOURCE: Freezer not cold enough, refrigerator not cold
This could be the defrost timer or the defrost heater coil... The evaporator coils are located at the back of the freezer compartment. To access you will need to remove all the racks and then there is a cover held on by a few screws at the back of freezer and under it you will see the coils... Do not beat bang or scrape them... Use a hair dryer or heat gun to melt ice or you could just use hot water . Put your model #.JCB2388GTB into searspartsdirect.com and they will show parts diagrams.
If I can help with anything else please let me know.
Posted on Apr 13, 2010
I have an Amana bottom freezer refrigerator model bc20tw that runs all the time. The freezer is cold but not enough to harden ice cream.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 10, 2011 | Refrigerators
Fans keeps running and the freezer is cold but not enough to harden ice cream
Look inside the back wall inside freezer and if you see ice building up then your Amana needs either a defrost timer=> 67001036 Defrost Timer or you may be having problems with the defrost heater=> 67002493 Defrost Heater Here are some large pictures to help you locate your parts that may be defective=> Amana_ARB9058CS_Evaporator_Components item location number 15 in lower left side of photo. In this case I think your refrigerator may need the defrost timer below but I would like you to manually turn the clock on the time clockwise slowly until compressor and fans stop running. The defrost timer is located inside the fresh food compartment and just behind the controls for adjusting temps inside fresh food compartment location=> Amana ARB9058CS Controls That is my most likely guess the timer but sometimes it will be the defrost heater or defrost thermostat affect these also here=> 12001937 Defrost Thermostat
I will be here if you have questions please ask, Thanks Sea Breeze
May 09, 2011 | Amana ARB9058CS Bottom Freezer...
At maximun temperatura, not cool enough. model ARB190 ZCW
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Apr 29, 2011 | Amana Refrigerators
Refrigerator is not cold, but it is definitely getting power. It is an amana model abb1924deq
Refrigerator
heatman101
Feb 06, 2011 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Amana side by side.. cold but not cold enough, fan not running. Had a repair man come and replace a little switch but still not working. help
heatman101
Jan 29, 2011 | Amana Refrigerators
Amana frig model#scd25tw freezer and frig not cold enough
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 28, 2010 | Amana Refrigerators
Amana drs2660bw refrigerator won't make ice any more
if freexer is not cold enough . this causing low or no ice prod . so ck the fan under neath and clean the coils in back . if this does not correct problem . you may have a bad ice maker .. mm
Apr 18, 2010 | Amana DRS2660B Side by Side Refrigerator
Refrigerators Logo
134 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
