Question about Lexmark X1240 All-In-One InkJet Printer
Power button keeps blinking after paper jam was removed. Will not turn off and on again. It just blinks! I've unplugged it and plugged it back in but it just keeps blinking.??????
  • 400 Answers
Try to reset it by removing the power plug form the printer and waite for about 10 minutes ,then reconnect the power cord switch it on again and see if the error has gone.
Also reinstall the software for the printer and see what error code it provides.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on May 11, 2009
Why won't the paper jam error code clear on HP 3930
First, check to make certain there are no small pieces of paper stuck in the gears of the rollers and carriage. You may have to reach in through the paper tray to move the carriage to see both sides. To do this, the printer must be unplugged.
If you are certain you have cleared the jam, I would do a power reset:
With the printer on -
* unplug the power cord from the back of the printer
* unplug the power cord from the wall outlet
* wait at least 15 seconds
* plug the cord back into the wall
* plug the cord back into the back of the printer
* printer should turn on by itself, if not press power button to turn on
* try to print a test page: (With printer on - while holding the power button in, open and close the front cover of the printer 4 times, then release the power button, self-test should print.)
The following link from the HP Support site is a step-by-step guide to removing paper jams. You may want to follow them to ensure you have cleared all the jams and reset the printer correctly.
The HP Product Stops Printing and the Power Light Blinks or Mechanism...
Jul 14, 2014 | HP DeskJet 3930 InkJet Printer
When i hit "print" the
Does the red light blink or stay on sterady?
Issue: The Compact Photo printer power button is blinking red.
Solution: Turn the Compact Photo printer off, then back on again.
"Paper Jam" appears on the digital camera LCD Turn the printer off and disconnect the power cord from the printer. Then reconnect the power cord and power on the printer. If the printer fails to eject the paper, the printer may require service. Contact the Canon Customer Support help desk for assistance.
When you power down I would recommend also unplugging the printer from the power supply (wall outlet). Let it rest 5 - 10 minutes and then plug back in.
The manual says a blinking red power light indicates a problem in the printer, but the only solution provided it to turn off and on.
If there are no paper jams, and no other error messages hoepfully a completr power down will clear the error.
Issue: Printer's power button lights red without the camera's LCD monitor displaying any error message.
There is a malfunction in the printer.
Remove the paper from the paper-handling slot and take up any slack in the ink sheet. Turn the printe's power off and turn it on again.
If none of this helps I would check to see if my driver is current:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/selphy_cp510#DriversAndSoftware
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Canon Selphy CP510 Thermal Photo Printer
Printer want print
o.k. you said you cleared the paper jam.. double check to make sure everything is clear.
Then try hitting the o.k. resume button. If this does not clear your problem try unplugging the power wire from your printer. Wait like one minute and then plug power back in.
Hopefully this resets your printers memory.. if not try pressing o.k. resume again.
I believe this should help you.. If it does not please write back..
thanks for choosing Fixya
Mar 29, 2010 | Lexmark X1240 All-In-One InkJet Printer
Three yellow blinks, one green blink
the printer needs to be reset.: remove the power cable from behind the printer.then keeping the power button on printer pressed ,reinsert the power cable behind the printer again.then leave the power button,printer will initialise and then reset itself.ready to print after this.
thanks.
Jul 08, 2009 | Canon Office Equipment & Supplies
Problem starts with "paper jam" messager. Can not shut down as light keeps blinking and "shutting down" message is on screen.
hi!!!! in your case,try to unplug the power of your printer and check the material that stock inside the printer that can cause the printer paper jam and after you check to plug it back.It is normal when the printer is blinking when the printer is paper jam because that is the error when your printer is paper jam.
May 11, 2009 | Office Equipment & Supplies
Constant yellow blinking light, no paper jam
I found this on the HP support site:
The power light is on, and the resume light is blinking.
c00109831.gifc01272271.gifc00109834.gif The printer might be waiting to complete a print job or to receive data from your computer.
Solution
Wait for the printer to finish the current task. The printer is waiting for the ink to dry on freshly printed paper.
Solution
  1. Remove the paper with fresh ink.
  2. Press the resume button.
The printer might be out of paper.
Solution
  1. Load paper in the paper tray.
The printer might have a paper jam.
Solution
Clear the paper jam. If the resume light continues to blink after the paper jam is cleared,
OR
if the print carriage is stuck or making a grinding noise, then follow these steps.
Solution
  1. Lift the top cover of the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts. Unplug the power cable from the wall outlet.
  4. Movethe print carriage toward the middle of the printer (this proceduremight take a couple of tries to get the timing correct).
  5. Remove the print cartridges and close the top cover.
  6. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover.
The printer may be ready to eject banner paper.
Solution
Press the resume button to eject the banner paper.
Mar 14, 2009 | HP DeskJet 5550 InkJet Printer
Failure to print
Here's what we did: Lifted the lid and turned off printer. Then turned on again. Unplugged power cable from back of printer, moved the carriage toward the middle of the printer. Took out cartridges and closed the lid. Plugged the power cord back in. Reinstalled the cartridges. After the alignment page it worked fine. These instructions are paraphrased from HP website troubleshooting. I don't have any idea why any of it worked, but it did and I'm grateful.
J
Aug 29, 2008 | HP DeskJet 932c InkJet Printer
Problem with HP 7450 and "Paper Jam"
hi, mezz
try this
There are 2 different types of flashing patterns with those two lights on the printer.
Resume light and power light BLINKING ALTERNATELY
Problem: Paper is jammed in the printer.
Resume blinking SIMULTANEOUSLY with power light
Problem:
The print cartridge carriage is stuck.
Solution:
1. Open the top of the printer.
2. Remove anything that is blocking the carriage path.
3. Turn the printer off.
4. Turn the printer on.
Problem:
There is something wrong with the printer. (I didn't write it, I am pulling this from actual HP tech documents, so don't blame me on this one) :)
Solution:
If the printer will not turn off, unplug the power cable from the electrical outlet or wall outlet.
Unplug the power cord from the back of the printer.
Wait about 30 seconds.
Plug the power cord back into the wall outlet.
Plug the power cord to the back of the printer.
oke, post in me back
tq
cropp
Jan 24, 2008 | HP Photosmart 7450 InkJet Printer
Paper jam
dear yelly
try this methode
Problem:
Solution:
Problem:
Solution:
oke,thanks
cropp
Jan 17, 2008 | HP Photosmart 7450 InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
196 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
