Question about Cavalry Storage Cavalry CAUH 1TB USB 3.0 Black External CAUH3701T0 USB 2.0 Hard Drive
I bought 1 TB hard disk a year ago. All of sudden it's not getting detected. not even volume label. i have very imporant data backed up. Can you offer any suggestion ?
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Posted on Mar 21, 2011
I bumped my Seagate 1 TB USB 20 Hard Drive off my computer. I tested it immediately and it was still detected by my PC and seemed to be fine. Later I heard a beeping sound coming from it and it is no...
In my opinion, the r/w heads have crashed on the surface or malfunctioned so that the voice coil has retracted the heads and will not allow the disk to function, thus the beeping. You have to decide if the data is worth recovering, i.e many bucks for a recovery company to get your data. If you open it up, it will allow dust in that will contaminate the data. In order to recovery the data, the disk has to be opened in a ultra clean environment and the disk taken from that drive and placed in another drives electronics and heads so that the disk will operate and your data can be copied out to another drive. As you can see it is a labor intensive process that will cost. Also the data recovery company cannot or will not guarantee success, and you still pay for them to try.
Jun 10, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
I have had this hard drive for about a year now and it has been nothing but problematic. I reformatted like 4 months ago to ntcc as was advised it would make it more stable... It was great until a few days...
The bad news is that I think you have a bad drive. There's not much you can really do. A few little
things that you might try as a last ditch effort are make sure your USB connection is good use a good quality cable and hook up the drive to the back USB instead of the front this may help.
If the drive comes back alive try to backup your stuff right away. I wouldn't do this in very large
blocks and back up the most important stuff first. doing mass transfers of data can stress this drive even more.
If its a software problem, say some kind of malware is causing the problem get a copy of Linux Mint
and see if it will mount the drive. If its a malware problem Linux shouldn't be affected by it. Linux Mint is a Live Version that can be run from a CD-ROM and has all the tools to mount NTFS filesystems. and transfer data between them.
If a drive goes bad it usually gives signs it will click and whir continually with a funny rythym. If this
isn't happening then the drive may be good and the USB controller may be bad. If this is the case
the encased drive can be reomoved and unplugged from the USB controller and plugged into and
external hard drive cable or adapter.
If worse comes to worse one of your local computer repair shops may do data recovery BUT it can
be very expensive. If its your family picture album, your bands demo the've been working on for a year then going this route may be an option but backing up roms, mp3's and movies and such
will probably cost you more than its worth.
Apr 30, 2011 | Verbatim (96759) 1 TB USB Hard Drive
My HDD does not detect its complete capacity, it works just with 7.87 gb when must be 1tb, I would please you so much if you know something about this hdd problem. Thanks!
Many, many, years ago, motherboards did not support any disk-drive larger than 8GB.
Is this the first time that you have tried connecting your 1000GB disk-drive to your computer?
Apr 02, 2011 | Samsung Spinpoint F1 HD102UJ 1TB 7200 RPM...
Drive not detected in windows, repeated ticking sound when powered , no life on disk, unreadable disk. i have an identical wd 1 tb green hdd .. how do i repair/recover data?
Did you set the jumpers on the hard drive to what you are using the drive for like master or slave or cable select. If you are putting it on the same cable as another hard drive you have to pick weather it is the master or the slave.
Feb 21, 2011 | Western Digital WD Caviar Green WD10EARS...
Hello, I just bought a Seagate Free Agent Go 1
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Nov 20, 2010 | Seagate FreeAgent Go (ST910004FAA2E1RK) 1...
Hard disk not detected
You can't do very much, the damage is already done. The only thing you can do is to remove the hard disk from the case, put it in a pc and try to access it from there - most likely you will have to use a recovery soft to get some of your files back. Once that's done test the disk for faults using HDTune, the free version. If it reports errors, even small ones, then it's dying (or already dead) - junk it and buy a new one.
Jun 01, 2010 | Western Digital My Passport Essential SE...
WD 1 TB- WINDOWS can detect but cannot see in my computer
if the disk is not in Computer Management then the disk has a major problem. it should be there but in black because u need to initialize it.
Apr 14, 2010 | Western Digital My Book Essential 1TB...
Lights on nobody home
Well if it is less than 2 or 3 years old you could contact them to attempt a sawp out of the drive. Over that - replace the unit. IF you do - you might want to consider a duel disk enclosure so if a drive dies, your data does not. you can build one yourself (1 TB duel drives, Raid 1) for a total of 252 bucks, with good drives (Seagate - Barracuda) Yes I swear by the Seagate Drive. For off teh shelf they have worked very well in every application I have deployed them.
I've been burned by too many single drive failures - even when I have the data backed up it is still a royal pain.
Jan 25, 2010 | LaCie Big Disk Extreme with Triple...
Western Digital 1 TB not recognized windows XP
disconnect it and reconnect
if its still not working then we can try the reg fix
Dec 07, 2009 | Western Digital MyBook Studio 1 TB USB...
It was 5 months since I bought the 1 TB hard drive.A couple of days ago,it was working as it should.But today,when I opened it to see a movie all files (or maybe all Data) were gone!And as if that was not...
Yes, power cuts, surges, low voltage, variable voltage and any sudden changes in electricity can cause a hard drive to fail or act improperly. If the drive had failed, though, you wouldn't be able to see or do anything with the drive now. Are you able to save anything to the drive now? can you browse to it and save a small text file or document? If you can save a document and read it from the drive now, the drive isn't completely failed, and your data may still be recoverable.
May 11, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Cavalry Storage Cavalry CAUH 1TB USB 3.0 Black External CAUH3701T0 USB 2.0 Hard Drive Logo
169 people viewed this question
Top Cavalry Storage Computers & Internet Experts
Arora Singh
Arora Singh
gary433
Glenn Smart
Glenn Smart
Are you a Cavalry Storage Computer and Internet Expert? Answer questions, earn points and help others
