Question about Canon imageRUNNER 5000 Copier
Need to remove the HDD from an old Canon IR5570 copy machine, where is this located?
  • Canon Expert
  • 287 Answers
Hello msg,
Remove the upper rear cover (6 screws). Once removed you will see a large polished aluminum cover to your left. This covers the main controller and hard drive. Remove the 4 screws of the cover and remove it. This will expose the hard drive to you. CAUTION !! There will be a small cicuit board just to the right of the hard drive that needs to be removed. It is the counter PCB. Remove the one screw that holds it in place and "un-dock" it from the main controller so you will have room to remove the HDD. Remove the 2 screws for the hard drive and slide it to the right . Hope this helps. please let "FIXYA" know if i did help you. Take care SPINAL
Posted on Mar 26, 2011
Hallooo ... sp, what's the difference with the IR5570 IR 6570 .. thanks
-IR5570 : 55 page/mn
  1. 20 GB Hard disk drive
  2. 512 MB RAM
  3. Scanning resotion 600*600 dpi
  4. Copy resoltion 1200*600 dpi
  5. Print resoltion 2400*600 dpi
IR6570 : 65 page/mn
  2. 512 MB RAM
you can use this brochure to see more: http://www.usa.canon.com/cpr/pdf/Brochures/copier_ir_6570_5570_5070_brochure.pdf
Dec 07, 2010 | Canon imageRUNNER 5570 Copier
Im have trouble ir 5570 code eror e821
hallooo ... sp,
Nov 30, 2010 | Canon imageRUNNER 5570 Copier
How do I access the hard drive (to replace) on a Canon imageRUNNER 5000. Where is it located/how do I remove it?
Points to Note When Replacing the HDD
1. Take care to avoid damage by static charge.
2. Keep the HDD unit from impact.
1) Remove the rear upper cover and the
reader rear cover.
2) Remove the three screws , and detach
the cover.
3) Remove the two screws , and disconnect
the two connectors ; then, remove
the HDD unit.
4) Remove the six screws, and detach
the HDD.
When mounting the HDD unit, be sure that the flat cable is under the plastic sheet of the HDDupper case.
here is a link to the location of the HDD http://i51.tinypic.com/htvitg.jpg
Obs:
1) Replace the HDD unit.
2) After assembling the machine, connect the power plug to the power outlet.
3) Connect a PC to which the Service Support Tool has been installed.
4) Turn on the PC, and turn on the main power switch while holding down both '2' and '8'
on the keypad.
5) Using the Service Support Tool, format the HDD unit and install the system software.
Nov 16, 2010 | Canon imageRUNNER 5000 Copier
Does the Canon Imagerunner c3100 have a hard drive to store copied images?
Hello kaiserma.Yes the C3100 has a HDD.It is 20G.To locate it, remove the rear cover.In the upper right section you will see a silver aluminum box.The hard drive is located wthin it.I hope this helps. :-)
Apr 26, 2010 | Canon imageRUNNER 400S Copier
Canon IR5570 - Problem: Black Copies The following parts have been swapped out from a working machine: DC Controller, HVT, laser assembly, reader unit, drum assembly, transport assembly, all the corona...
As I see that you have done near about all troubleshooting steps possible with the copier . Would request to check with Canon on the same if the copier is in warranty.
Canon Customer Support Center Hours: Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays Phone: 1-800-OK-CANON (toll free)
1-800-652-2666 TTD: 1-866-251-3752 (toll free) Email: carecenter@cits.canon.com For additional support options: www.canontechsupport.com
Thanks
Jan 15, 2010 | Office Equipment & Supplies
ERROR E840 FOR CANON IR5570
This is a fuser shutter error. Subcode 0001 is that the shutter is not being detected by the shutter sensor. 0002 is that the shutter is moving but on/off detection timing is off. When the copier is powered up you should here this shutter trying to find the home position. If the error occurs then, most likely the sensor is bad or unplugged. Have you done any fixing repairs recently and got this error?
Nov 04, 2009 | Canon imageRUNNER 5570 Copier
Waste toner collection IR 5570
remove the small lower( rear)right side cover 2screw then you will see the waste bottle youcan pull it out and throw away the waste toner
Jul 15, 2009 | Canon imageRUNNER 5570 Copier
How to replace HDD IR5000??
how to clear hard disk IR 5000 and where i can find hard disk software
Dec 20, 2008 | Canon imageRUNNER 8500 Copier
Ir5570 losing network connection on sending only
Is your firewall on the router or on the server? Are any of your computers using Windows firewall, McAfee, or norton security software?
Oct 06, 2008 | Canon imageRUNNER 5570 Copier
5570 imagerunner question
If you can find the main power switch to the machine, you can find the waste toner bottle. Find the doors on the right side of the copier that are used to clear paper jams, or find the bypass tray. Then look towards the rear of the machine and you will find a small cover where the on/off switch is located that is attached with two screws. Remove the screws, pull out the bottle and dump the waste. Slide the bottle back, reattach the cover and you are done.
Jun 05, 2008 | Canon imageRUNNER 5570 Copier
Canon imageRUNNER 5000 Copier Logo
1,175 people viewed this question
old marine
old marine
