Question about Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966
Briggs & Stratton Engine Won't Stay Running
I have an MTD/Yard Machine Edger with a 3.5 Hp Briggs & Stratton engine on it. It starts easily, runs for 2-3 seconds, then stops. This engine has the carb on top of the gas tank and uses a vacuum or venturi effect as a form of fuel "pump".
I've replaced the gas, removed the carb, cleaned it with carb cleaner, cleaned the air filter, removed and checked the plug and still the same issue.
During the 2-3 seconds, I can force gas into the carb by pressing the priming bulb ... the engine will stay running indefinitely. This makes me think the engine isn't sucking fuel into the carb ... how can I fix this?
  • Anonymous Mar 20, 2014
    cleaned carb,replaced fuel lines & bulb,cleaned air filter. still only runs on half choke
    Problem Solver:
  • 3 Answers
Make sure none of the hoses are cracked or loose fitting
Posted on Aug 03, 2008
    Problem Solver:
  • 7 Answers
Check the vent on the gas cap or change the cas cap all toghether.
Posted on Jan 28, 2009
  • Eteban Charpentier Jan 28, 2009
    clear the vent on the gas cap or rerplace the gas cap all toghether.
  • 120 Answers
Could be that the screen inside the fuel tank at the pickup is stopped up or glazed over
Posted on Aug 16, 2008
Engine is misfiring.
Put the old plugs back in. The new plugs my not be gapped correctly or one may be bad.
May 05, 2014 | Briggs AND Stratton Intek Briggs &...
13.5 HP Briggs & Stratton engine will not start
Check for spark from the coil if you have a spark tester use it if not remove plug and leave it attached to the coil wire turn engine over if you do not have spark either the ground wire is not releasing or coil is bad
Nov 09, 2013 | Mtd Garden
22 hp b/s won't stay running
check spark make sure its bright blue but sounds like a dirty carb needle valve isnt opening enough not letting enough fuel in
Jun 25, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a Yard Machine Lawn mower by MTD it has a briggs and stratton engine. The pull cord pulls, to easily I might add, but will not start the lawn mower. It doesn't seem to engage the motor. What might...
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
Oct 23, 2010 | Mtd 22" Yard Machine Push Mower
Have a Yard Machine riding mower with 21hp Briggs Stratton engine OHV/IC V-Twin. when I turn on key nothing happens. How many switches control the start motor from the ignition and where are they located....
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Have to choke to keep running
this is not hard to do here is what you need , 1 can of carb cleaner anykind will do , a 10 mm rench to remove the bowl 7/16 socket . now remove the carb take a good look where the spring is before you take the carb off it muct go back in the same hole , now that you have it off take the bowl off remove the float place to the side here is the fun part look in the carb you will see some small hole spray them this will clean all of the old gas out if you can let it set for about 10 min then do it again blow out with air if you have one nothing else to do but reinstall this works most of the time ...Good Luck..
Aug 16, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
Jun 18, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Carburetor adjustment
have you checked the air filter,if that is clean I think I would replace the carb, diaphram.
May 05, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966 Logo
4,249 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
