Question about Poulan Garden
I have a Poulan Pro [PPB350] gas lines were shot,primer to,dont know where gas lines go!!!please help
SOURCE: gas lines on Poulan Pro model 112
i need a diagram or manual for a sears craftsman weed eater so i can put new
gas lines on it
Posted on Oct 19, 2008
  • 149 Answers
SOURCE: poulan 2150 w/ walbro wt324 carb fuel line reassembly
the fule line that comes from the filter/ pick up will go straight to the nipple usualy the one closest to the middle of the carby.
the other hose comes from the carby to the in or **** side( punp it you can feel it)of the primer and then goes to the tank that is the return/ prime, nothing is conected to it in the tank. if you have the carby one the wrong way around it will not prime. just swap them over..
Posted on Jan 12, 2009
joboo1
  • 257 Answers
SOURCE: i have a poulan 2050 chainsaw. hookup primer
hi, Yes it is and should go from tank to primer to carb. Good Luck!
Posted on Feb 09, 2009
  • 97 Answers
SOURCE: routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
Posted on Mar 21, 2009
  • 376 Answers
SOURCE: how to remove clutch on Poulan Pro PPB350 gas trimmer
Poulan makes a tool, part # 530031112, with two prongs that fit the grooves on the sides of the clutch. It fits most Poulan saws and trimmers made in at least the last decade. I use a butterfly impact and 3/4 impact socket and turn CLOCKWISE to remove. There should by an arrow and the word off stamped on the clutch This is the tool... That should work for you. Dwainb076e56.jpg
Posted on May 19, 2009
Hi Sirs, I have a Poulan Woodshark model 1950. The gas lines deteriorated and I bought new ones, together with the primer bulb and the chain. Now I can't remember how to connect the lines. I need help....
The fuel line from the tank with the filter on the end goes to the carb inlet, closest to the metering cover usually a chrome cover held with four screws, the other conection on the carb goes to the suction side of the primer bulb, normally the shorter of the two conections, the pressure side of the primer goes back to the tank, this pipe just sits in the tank to act as a return, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank.
Jul 23, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
I purchased a 260 Pro 42cc. I just got it out and when I pushed the primer bulb it did not return to the un-depressed position. There was no fuel in the bulb. I pulled the lines and gas pumped out of one...
because you interfered with it , the warranty is void and if you have a blocked line ( unlikely) then any repairs are at your cost
it could be a stuck valve under the primer bulb that is the problem so remove the bulb and check the valves operation
Jul 11, 2017 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Have a poulan pro ppb350 31ccweed eater runs short time. put a carb kit in carb engine runs a short time.then dies.not sure if fuel lines are in correct place on carb?
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the fuel tank.
Sep 11, 2010 | Poulan Garden
I have a Polan Model 2375 Wild Thing Chain Saw. The fuel lines have deterioated and I need to know correct routing of fuel lines. The primer bulb has to line connectors, one small diameter and one large...
A Poulan IPL for your saw “2375LE Gas Saw Type?” (LE is code for WildThing; if your saw is beyond serial -2 look at a saw without the LE; it makes little difference to the fuel system) can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
  • Small hose (filter on bottom) long enough to reach all corners inside tank, to lower carburetor connection. Please leave the 2 carburetor connections long enough to reverse until the saw is running.
  • Upper carburetor connection, small hose to suction side of primer.
  • Pressure side of primer (large hose) to tank fitting.
The IPL is deceptive it appears the filtered hose connects to the primer; it does not.
A typical fuel system and suggestion or 2 follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan chainsaw primer bulb replacement
You can find replacement parts on amazon, here Amazon com poulan chainsaw chain parts. I hope this was helpful. Cheers
Mar 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How to remove clutch on Poulan Pro PPB350 gas trimmer
May 18, 2009 | Poulan "Poulan" Pp325 17" Gas Brushcutter...
Carburetor overflowing
Gas line from primer bulb to carb may be cracked or broken. Check gas lines for damage. If not that then there maybe an overflow problem in side the carb caused by the float shut off not seating correct or worn "o" ring etc.
May 16, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
208 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
