Question about DeLonghi Heating & Cooling
Water leaks out from bottom of unit - DeLonghi Heating & Cooling
    Brigadier General:
  • 4,736 Answers
If it's a window unit, it may not have enough slope towards the rear for the water to drain outside. Or the unit is freezing up and you're seeing water come out the front due to icing. If that's the case, turn the unit off and let it thaw. Some units have a defrost cycle. Check your Owners Manual for that.
Posted on Mar 21, 2011
Why is my keurig 560 leaking water from the base
Most likely the water lines inside your unit are leaking. If you can take the bottom of B60 off and look inside the unit. Usually, the line that comes off the water pump is leaking at the T connector. If not leaking there look for other signs of leaking while the bottom is off. You can call Keurig 800 number to see if your unit is still under warrenty. Hope this helps.
May 28, 2014 | Keurig B60 Coffee Maker
Water coming from the bottom of unit
There is a leak in the line or chamber that holds the water. Check it for a leak. This could be dangerous as is is right there with electricity. If it is a rubber piece, that can be replaced fairly cheap. This anyway is a pretty simple fix. Let me know if this helps.
Feb 02, 2013 | Krups XP3200
Keurig b40
We need to determine where the leak is...
Unplug it...
Start by removing the water resevoir...dry out what you can with paper towel...
flip it over on a table with a bath towel. Take off the metal bottom plate
you can then check for water inside the unit.
since you didnt say where the water is coming from... the K-Cup arm or the bottom...
I will assume the bottom is where the water is coming from.
Hoses on these units are fastened with 4 inch "Ty-Wrap" nylon fasteners.
You may have a broken one, and need to replace one... hopefully it is located on the bottom between the water fill and the main water motor... which you shouold be able to see when the bottom metal pan is removed...
If the water is coming out from the top. then I suspect hot water expansion is bypassing one of the valves, or there is a nylon strap/hose combination you cannot see instde the unit...
Hopefully it';s the bottom
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 17, 2010 | Keurig Elite B40 Coffee Maker
Water leaking out of bottom of unit, near reset
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
p
Nov 11, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Airtemp - 25 yrs old. Water leaks from bottom of
Is the unit level? it's pulling moisture out of the air and not draining threw the drain hole normally it's cause by the unit not being leveled.
Aug 10, 2009 | Heating & Cooling
Water accumulates at the bottom of the freezer unit and leaks
You must clear the drain of anything that would cause water to pool up after each defrost cycle. Check your door gaskets for wear. Air entering the ice box can cause excessive frost.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 06, 2009 | Refrigerators
Condensation leaking out of unit
if it is the indoor unit leaking, make sure that all your drain lines are clear.... if you're talking about the outdoor unit leaking water in the heat cycle...that is normal.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
May 16, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
67 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
