Question about Norelco 8160XLCC Electric Shaver
One post of the three that turn the cutter has broken off at the tip. Can this part be replaced? Thanks, Marty Grossman
  • Norelco Master
  • 1,625 Answers
The gear tips for model 8160XLCC come as part of an assembly. You will find the part at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-8100-series-motordrivegear-assembly-p-608.html
Posted on Mar 21, 2011
Testimonial: "Thanks for the tip. Norelco said they did not have a replacement part. Guess they want to sell you a new shaver."
Have a nail gun made by Grossman that needs repaired
I have spent over 20 years in this business and have never heard of that brand. It may be a private label of a more common brand. If you could post a picture of it I may be able to identify it.
Feb 27, 2012 | Tools & Hardware - Others
How to fix a broken Maestro Lutron button?
I will take anybody's broken Lutron dimmers.
Please let me know...
Marty
Feb 02, 2012 | Lutron Electronics MAW603RHWH Maestro 3Way...
When turning on garbage disposal power turns on but does not spin
Is the motor rotating, and cutter disc stationary?
If the motor is running but cutter disc is not moving, then disposal is probably broken and needs replacement.
If the motor is not rotating, and is making humming sound, then do not keep power turned ON or motor will burn out.
Then use allan wrench on bottom of disposal to rotate the motor until disc rotates freely. Also use wood broomstick handle down into disposal and wedge against side of sink opening to free cutter disc.
Also view ez disposal replacement steps:
http://www1.fixya.com/support/r7929008-replace_garbage_disposal
Oct 01, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Motor seized
If cutter blade is not rotating freely, then use allen wrench in slot on bottom of disposal or use wood boom-stick handle in sink upening to wedge cutter blade loose.
If blade rotates freely and motor stopped working, then disposal is broken.
I wrote ez disposal replacement tips from years when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Apr 20, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do i change the blades
Disconnect the planer's power cord, then use the T-wrench that comes with the planer to remove the four screws that secure the top of the planer. Lift the top to remove it from the planer.
Remove the three wing nuts holding the dust cover over the cutter head. Rotate the dust cover up to unlock it from the fan housing, then push the cover to the left to disconnect it. Remove the dust cover from the planer to expose the cutter head.
Rotate the cutter head with a piece of scrap wood until the lock on the side of the cutter head engages. All eight screws in the cutter head clamp should now be visible. Remove the screws using the T-wrench, then turn the T-wrench upside down and use the magnet in the head of the T-wrench to grab the clamp. Remove the clamp to expose the knife underneath. Use the magnet to remove the knife.
Press down on the cutter head lock to free the cutter head. Use some scrap wood to turn the cutter head for access to the remaining two knives. Follow the instructions in Steps 3 and 4 to remove and replace those knives.
Mar 13, 2011 | Dewalt Tools & Hardware - Others
No pilot ignition, air is ok
Some times when I use my plazma cutter its a cut master 42 .I would some times have to turn it off and turn it back on for it to work .And here lately all it does is air come on and off its like its has a heart beat and then have to cut it off again . I have replaced the tips and electrodes .And nothing .I have took thee electrode out and clean the white dust build up and works fine for a little while
Feb 01, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Engine run but don't turn
You're a bit vague in your problem description here, but I'm assuming you mean that when you give your machine gas that the cutting head will not turn. First I would check the cutter head to be sure that no trash has wound itself around the shaft preventing the head to turn...if that is not the problem turn the cutter head by hand and check to see that the bearing inside the cutter head has not seized, it should turn freely with no noise....if no joy check the cable which runs through the shaft from the engine to the cutter head it may be broken or frayed, also check to see that there are no problems with the clutch (broken springs, broken pads, or a broken key) that should do it ...hope this helps...;-D
Aug 09, 2010 | Ryobi Garden
Plasma cutter
in order to cut the thicker steel just boost the air pressure this will allow you to thourghly blow through the steel. just remember not to turn it up too much. this should do the trick. please rate
Sep 15, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
Norelco 8160XLCC Electric Shaver Logo
97 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
