Question about HP Compaq 6730s Notebook PC KS129UTABA$375 instant savings
My cd/dvd driver doesn't write dvd's at all but has no problem writing cd's. Lately it doesn't open up inserted cd's and dvd's either. It opens some but not all. I have tried to write dvd's repeatedly and it writes for some time and then stops at the end and ejects the disk saying: insert a writable dvd. And the problem is not the disks because on other computers I can use them. It is HP 6730s.
  • 76 Answers
Sounds like your DVD Drive has had it! Happens to all of them at some stage, here is a replacement from ebay:
http://cgi.ebay.co.uk/HP-AD-7561S-Laptop-DVD-RW-SATA-Drive-/300522267766?pt=UK_Computing_LaptopAccessories_LaptopDrives&hash=item45f885e476
Hope this helps
Posted on Mar 21, 2011
My DVD/CD-RW drive isn't recognized/ doesn't play disks.
It may be bad. Has the laptop been damaged? Dropped? Open Device Manager, DVD/CD Rom drives, is it listed? In Start Menu, Computer, Is it listed? Try re installing the DVD rom driver, the MS Vista 32bit drivers can be found here: http://www.dell.com/support/drivers/us/en/04/Product/vostro-a860
Feb 02, 2013 | Dell Vostro A860 Notebook
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
Cd player doesn't work
You can see a small pinhole near your CD Eject button on your CD Drive. Insert a blunt pin into it and push. The drive shall open!
May 31, 2012 | 2002 Volvo V70
My cd burner doesn't read or write ...
you might have to physically unplug the leads for this cd rom then plug them back in this should activate the found new hardware wizard
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the sound drivers could be on it
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
May 26, 2011 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
My dvd drive is not recognizing any cd or dvd. it is since 1 and 1/2 months. even i cannot erite any dvd and cd. plz sir tell me some solution for it.
Make sure the light on the drive is coming on when you insert a disk. I am assuming that drive tray opens and closes when you press the button and that you are not opening the tray manually or forcing it open. Try to spray some compressed air into the drive with the tray open incase anything is interferring with the laser. Has anyone been inside the computer lately that may have disconnected a cable from the back of the drive? Not to be funny, but make sure you are inserting the disk right side up. You may just have to buy a new drive.
Mar 08, 2011 | HP Computers & Internet
How do you copy a cd on my laptop?
If it's an audio cd you need to rip it - use
http://www.softpedia.com/get/Multimedia/Audio/Audio-CD-Rippers-Encoders/Express-Rip.shtml
Feb 02, 2010 | Toshiba Qosmio F45-AV412 Notebook
Does not recognize any cds
Insert a CD that has writing on the top, noting which way the lettering is facing. Close the drawer. Wait a few seconds. Open the drawer.
If the lettering still is facing the same way, the disk did not "spin".
So, the motor that spins the disk is dead. Replace the CD/DVD unit.
If the disk does spin, then the laser inside the unit has failed. Replace the CD/DVD unit.
Sep 10, 2009 | Computers & Internet
I can not seem to write DVDs anymore. I can watch DVDs, but when I insert a blank DVD the box that opens up only gives me the option to write CD's. Also if I look under my computer it recognizes that a...
1. are you using dvd's that are compatible with your dvd writer?
check if the specs on the dvd disk are the ones compatible with the your dvd writer. (check that the -'s and +'s match)
2. check also the computer or the dvd driver manufactorer for any firmware updates.
Dec 14, 2008 | Computers & Internet
HP Compaq 6730s Notebook PC KS129UTABA$375 instant savings Logo
151 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
