Question about Yamaha Mg82cx Stereo Mixer
I HAVE THE YAMAHA MG82CX MIXER POWERED MONITOR SPEAKERS COONECTED AND I NEEED TO KNOW HOW TO CONNECT IT TO MY COMPUTERS AUDIO ON AN ASUS P755M PRO MOTHERBOARD WITH REGULAR COMPUTER SPEAKERS ALREADY CONNECTED. PLEASE LET ME KNOW.
    New Friend:
You could purchase a usb audio interface and connect it to two of the channels for stereo, or one of the channels if your interface has a mono switch. I use the Presonus Audiobox and love it. Works great! WebRepcurrentVotenoRatingnoWeight
Posted on Nov 17, 2012
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 137 Answers
There is a main output, conect it to the aux in line or to the microphone line.good musics
Posted on Mar 21, 2011
I have no monitor signal
A little vague, there, Chuck...
We have no idea if you even know how to plug the thing in... an no, it's not obvious because some people don't. Describe your connections and a little more about the problem.
May 27, 2014 | Yamaha Mg82cx Stereo Mixer
Can I connect only one speaker to a yamaha emx 312 sc power mixer?
First it is certain that you would not want to plug both outputs of the stereo power amp into one speaker combining both channels into the same speaker. (see image from manual below - also link to manual)
Next I would be very concerned about only using the one side of the main amp out as it could cause an unbalanced load, or you could be driving the load into dead air connection and any of these conditions are destined to cause premature failure of the power amp.
Taking a quick scan of the manual for this unit, it appears what is pretty common to most powered mixers, hook up two matched speakers/loads to each chanel of the output.
Your best bet is to shed those monster cabs, there really is no need for them especially with this sized powered mixer, and get yourself a nice pair of full range cabs like EV1202;s, EV SX300's, or some nice 2 or 3 way 15" JBL's/
Just my opinon.
Link to Yamaha EMX 312 Owner's Manual:
Yamaha EMX Series Owners Manual
Dec 06, 2013 | Yamaha Music
Powering a passive stage monitor
A passive loudspeaker requires an amplifier to increase the power from the mixer.
An active speaker does not require an amplifier and will work direct from a mixer as the amplifier is built into the speaker box.
Jan 20, 2018 | Behringer Pmp3000 16 Channel Audio Mixer
Shud i get an external equaliser? i'm using MG166CX 16-Channel Mixer as the main mixer.
An external equalizer will not help this at all. The problem is likely within the amp (feeding the main speakers), the connections from the board to the amp, or the speakers themselves. In other words, the answer would be "NO." Best of luck!
Jan 14, 2013 | Music
The speaker connected to my Yamaha EMX 312 SC is not bringing out any sound when we use the microphones but the displays on the power mix shows there is activity.
Assuming that you have checked the speaker leads for broken connections and that you know the speakers themselves work okay (test with a different amp) and that you can hear sound on the headphone socket
  1. Check that you actually have the power amp switch in the right position for the outputs (monitor jacks or main neutrik/speakon sockets) that you are using (see page 25 of the manual)
  2. That your speakers are connected to the speaker outlets on the rear panel and not the 'main outputs' on the front panel, which are for use with a separate power amplifier
  3. Check the mute button is not in
  4. You have turned both the master volume controls up.
If none of the above solves the problem it is likely that the overload protection fuses on the amplifier output stage have blown and need replacing - take to a repairer
You can find the user's manual here
http://www2.yamaha.co.jp/manual/pdf/pa/english/mixers/emx512sc_en_om_d0.pdf
Feb 10, 2011 | Yamaha Emx312sc 12 Channel Stereo Powered...
Yamaha mg82cx locked up, all led's on, no audio signal
Check the power adapter. It is a 38 volt AC centertapped unit with 0.62 amp rating. Verify that you get 38 volts AC between two of the pins and 19 volts AC between any other pair of pins with an AC voltmeter.
Check that the connector is seated. These can sometimes seem to be seated but not fully in place.
Apr 24, 2010 | Yamaha Mg82cx Stereo Mixer
Where can I purchase a European compatible power adapter for a Yamaha MG82CX mixer?
what is the voltage/current/wattage of the unit this info should be on the back/underside of the unit, Also what type of power supply plug does it take? Maplin electronics throughout the uk or any good electronics parts supplier should be able to help you? Have you tried ebay etc?
Jul 14, 2009 | Yamaha Mg82cx Stereo Mixer
Hooking up Electronic drum kit to mider
sorry ...you haven't enough channels to mix all the kit ... you will have to run a stereo pair from the td8 to mg82 and mix it from the td8
Feb 01, 2009 | Yamaha Mg82cx Stereo Mixer
Yamaha Mg82cx Stereo Mixer Logo
469 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
