Need to know the kw of the fire as I have just moved house and there is no plate on the inside of the fire. Thank you.
    Brigadier General:
  • 4,736 Answers
Do you need to know the Kilowatt (KW) of the fire (KW is Electric output) OR the BTU Output (British Thermal Unit) which is heat ?
Posted on Mar 21, 2011
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
Am told that a cozymizer gas fire installed in conventional grate now requires additional ventilation. Only id marks on plate are "18N and input 9.6 kw. Can you advise?
I just happened to be looking at this site. I have just changed a Cozymiser for a Wonderfire (remote control). For fires over 7kw, you will need a vent in the room - which will cause a through draft. Our Cozymiser was 9.2 kw and without a vent, it was against regulations to use. These regulations came in after we acquired it in 1989! Our new 7kw fire is great and a vent is not needed.
Oct 10, 2011 | Heating & Cooling
The house in which I live has an electricity line of 2 KW. Will it be sufficient for 1.5 ton AC? Other equipments in the house are: Refrigerator, Fans and tube lights.
Lets calculate your loads :
1. AC 1.5 ton (TR) = 1.5 KW
2. Refrigerator = 0.2 KW ( I guess)
3. Fans = 0.1 KW ( I guess)
4. Lights = 0.2 KW ( I guess)
Total : 2 kW.
Remember that your appliance need more power for starting.
Now you know the answer if all my guess is correct.
For best , You can use multimeter to take measurement on your appliances current draws.
Warm regards, Jay
Apr 25, 2011 | Air Tools & Compressors
JVC KW-NX 7000, the spring loaded latch for the detachable face is broken so the face plate will not stay on therefore I cannot use my unit. Can I buy a new latch for this and if so where or do I have to...
If you still need help on the display faceplate, check this guy on ebay, he has all the jvc parts, I bought my faceplate touch screen from him, his user id is genecyrus on ebay NAU0005-001X
Oct 18, 2010 | JVC KW-NX7000 Car GPS Receiver
I disassemled the tilt steering wheel to my 1990 Chevy Suburban because the tilt was loose. The steering wheel moved side to side at the tilt location which was right above the gear shift lever bowl. I...
You will have to remove the lock plate and the turn signal plastic assembly, from inside the column housing, in order to access and tighten up the three hex screws that have come loose, allowing the tilt column to move side to side. I have done this numerous times, in the mid 90's, when the 80's GM tilt columns started to come loose with age. The hardest part is getting that lock plate off, and replacing it, if you don't have a lock plate puller, so make sure you have one or else get one, as it will save you lots of time and fustration. Good luck.
Oct 05, 2010 | 1990 Chevrolet Suburban
I am trying to find the KW rating of the HBL3550UC so that I can rough in the electric. They couldn't even tell me that info at the store. Thank you.
hi could not find kw rating but found it needs 30- 40 amp supply. it will tell you the kw on therating plate located around the door area.
Jul 23, 2010 | Bosch 300 Series HBL3550UC 30" Double...
I need a wire diagram for a hobart C44A
The lid to control box has diagram inside, the heat kw is in the metal ID plate on right end of top of control box
Oct 24, 2009 | Hobart Dishwashers
Kitchenaid oven model #KEBC207
this was taken from the installation guide
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kebc207&siteCd=WHRCOM#installation_instructions
Oven must be connected to the proper electrical
voltage and frequency as specified on the
model/serial rating plate. (The model/serial rating
plate is located on the oven door or on the oven
frame.)
Models rated from 7.3 to 9.6 kW at 240 volts
(5.5 to 7.2 kW at 208 volts) require a separate
40-ampere circuit. Models rated at 7.2 kW and
below at 240 volts (5.4 kW and below at 208
volts) require a separate 30-ampere circuit
Nov 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Brada dishwasher EF2401 - water in bottom
I just moved in to a new house with brada dishwasher, everytime I used the water leeks from the bottom, can somebody help me to fix it, or do you think I should throw it away and get a new one.
Sep 05, 2008 | Dishwashers
I need driver for KWorld KW-506RF-PRO
Aqui esta el driver del
KWorld KW-506RF-PRO http://driverscollection.com/?file_cid=390513268530012dba66801272d
Nov 25, 2007 | KWorld KW-506RF-PRO TV Input
Heating & Cooling Logo
161 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
