Question about Magic Chef MCD1311ST Microwave Oven
When I start the microwave, there is a screeching noise coming from below the rotation plate.
  • 37 Answers
Sounds like you have a motor going out.
Posted on Mar 21, 2011
Microwave makes grinding noise when microwave plate on turntable
check for the roller spider under the plate
small plastic item that has 3 (4) rollers that allows the plate to turn freely
May 25, 2015 | Microwave Ovens
Unit makes a lot of noise when cooking.
The exhaust fan may be loose, {check mounts} also, the turnable motor that rotates the plate often gets noisey before seizing, {remove plate to see if noise goes away} and finally the magnetron gets very loud near end of life.
May 16, 2012 | Magic Chef MCD1311ST Microwave Oven
Microwave MH6140XKQ doesnt want to start
Toss it out. The transformer is likely bad.
Nov 18, 2017 | Whirlpool MH1140XM Microwave Oven
Rotating Plate
The motor for the turntable is broken internally.
Apr 21, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Intense squeaking noise
When microwave is running, turntable squeaking when rotating. Can problem be fixed? Microwave is about twelve years old.
Mar 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a JES1142 which I purchased only one month ago. The turning plate rotates both clockwise and counter clockwise. When it rotates counterclockwise it makes a grinding sound. Why does it rotate bot...
It's normal for the motor to turn both ways, that's because of how the motor is made. As for the grinding noise, there's no reason the motor itself would make more noise turning one direction than in the other. The noise might be coming from the roller ring under the glass turntable. One of its wheels might be binding when it tries to turn counterclockwise.
Here's a test. Take the glass tray and roller ring out of the oven. Put a microwave-safe container with a cup or so of water in the oven and start it. Stop the oven and start it again, and the motor should turn the other way. If not, repeat this until you've seen the plastic coupling turn both directions. Note whether you still hear the noise as the motor turns each way. If you do, then there is something wrong with the motor and it should be replaced. If not, the noise is coming from the roller.
In either case, if the oven is truly only a month old it's still under warranty. Since you are concerned about the noise and are worried that the oven is defective, contact the store where you purchased it and see if they will exchange it or take it in for service. If the store can't help you, refer to the owner's manual for the service procedure to follow.
Hope this helps. Thanks for using Fixya!
Feb 13, 2010 | GE Microwave Ovens
Noisy rotating plate
check d rotating motor,
May 29, 2009 | Microwave Ovens
Magic Chef MCD1311ST Microwave Oven Logo
164 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
