Question about KitchenAid KAWS850L Top Load Washer
Leaking out the bottom of the washer - KitchenAid KAWS850L Top Load Washer
  • Rev Kev Oct 25, 2008
    Same problem: minor leak with a 2002 Kitchen Aid KAWS850LQO leaks about a half-gallon during a wash cycle. It is the pump? How do I check, lean it back and run a cycle?
  • 943 Answers
Thanks for the question Tip the washer back to the wall now you can see underneath the pump is right there at the front if you see the pump leaking replace the pump thanks for the question The appliance doc
Posted on Sep 11, 2008
Washer
No offense, but I think it's time for a new washer. The only thing that comes to mind for leaking would be a broken hose. Is it leaking out of the bottom bottom or like the bottom of the door?
Jul 06, 2013 | Washing Machines
Leaking at the bottom on front
sounds like the door gasket is leaking and needs replaced.
Jan 02, 2012 | Hotpoint WMA32 Front Load Washer
Leaking water
Yes, Remove two screws rrom bottom of washer using puddy kinfe release the top panel bysliding in at crack between top panel and body the water pump is at the bottom left and may be leaking from hoses the other posiabilty is the selonid that controls the water inlet may be leaking
Aug 14, 2010 | Frigidaire FWSB5700DS Top Load Washer
Washer leaking from the bottom
make sure your drain pipe is not backing up when washer drains
Jan 10, 2010 | Washing Machines
Water leaking from bottom of washer
Tub Seal is leaking and needs to be replaced
Jun 11, 2009 | Washing Machines
Leaking from bottom of washer
Do you have the little door at the bottom to collect lint and stuff that goes through the washer? I had a leaking problem once when I simply didn't tighten it enough. Check that.
May 06, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
Washer is leaking water at bottom
You should look at the machine's bottom first- try to find out from where water leaking from. In most cases it is the pump.In such a case it should be replaced. Good luck!
Jun 14, 2007 | Frigidaire FEX831CS Top Load Stacked...
KitchenAid KAWS850L Top Load Washer Logo
150 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
